First mcjMidiLoad Beta Available - Midi File loader script for Daz Studio
mCasualmCasual Posts: 4,607
edited April 2015 in Freebies
Released here
https://sites.google.com/site/mcasualsdazscripts5/mcjmidikit
Now with a manual and a little demonstration video
since ... a long time ago ... there's a PC ( Mac too? ) utility to convert a midi file into a text file
http://sourceforge.net/projects/mf2t-win32/
with my ( upcoming script ) the content of the midi file will be loaded
into the Daz Studio scene as a node named "midi"
the midi node will have up to 16 child nodes, which corresponds to the midi channels used
in the case of channel 10, the drum-kit node,
each drum used by the midi file,
will have a parameter slider ( int property )
that slider will be named according to the specific drum
in the case of musical instruments
each note used by the midi file
that slider will be named according to the octave/note : ex O4C#
in the 1st example below, the midi file contained only a drum loop
so the midi node has only 1 channel-node for channel 10
and the channel node has 4 drum-sliders, because the drum loop involves only 4 drums
each drum will get a series of keyframes, corresponding to their midi events
so, you will now have something to guide your animation !
i'll probably have something to automate some of the animation
for example, the script could animate drum pedals and piano keys
or highlight something
Post edited by mCasual on
«134567…10
  • mCasualmCasual Posts: 4,607
    and the synchro works perfectly if the .avi file from Daz Studio is forced to the exact frame rate ( 30.0 fps )
    480 x 270 - 912K
    edited February 2015
    tomorrow Amy ( Aiko3 ) will play that drum set
    ( which i may post on my site someday )
    incidentally i don't think i made sticks back in ........ 2007 when i modeled the set
    ( just a hardware render ... one can make it look way more swell )
    1280 x 720 - 253K
  • RuphussRuphuss Posts: 2,631
    great idea casual
    waiting for Amy to give me the groove
    the idea of loading midi footsteps to the feet nodes comes to my mind
    casual you think you could write a script like lageffect which I use often and like very much
    with a morph as follower
    maybe smile morph follows head node
    or breast up and down follows chest node
  • KeironKeiron Posts: 419
    You are a star !
    Can't wait to try it out
    Thank you
    Just out of interest I found that when I rendered the AVI using Daz Studio I met a few restrictions
    On a 32 bit Operating System the Daz 32 Bit version with 16 Gig of Memory, the AVI was restricted to 2 Gig
    On a 64 bit Operating System the Daz 64 Bit version with 16 Gig of Memory, the AVI was restricted to 4 Gig
    if the file produced "needs" to be bigger it may not play.
    To get over this I did the following in Daz Studio I outputed each frame as a jpg picture instead of an AVI, then used Virtual Dub 64 bit version to create the AVI. available from here http://virtualdub.sourceforge.net/.
    After you have loaded the single frames In Virtual Dub " remember to set the frames to 30" as it's default is 10
    I used the free Lagarith Lossless Video Codec available from here http://lags.leetcode.net/codec.html
    On a 5 min video Daz Studio made 6500 frames at 1920 x 1080. Virtual Dub made a file size of around 45 Gig uncompressed and around 17 Gig compressed
    Looking forward with great interest
    Kindest wishes
    Keiron
    Post edited by Keiron on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,759
    yes looking forward to this too
    Hi
    I've made a MIDI test file for a Piano in format 0 and 1 and it's wav file
    Would that be of any help?
    Keiron
    brand new drummer seat !
    note that drumming will most probably involve the use of mcjAutoLimb 2014
    http://www.daz3d.com/forums/discussion/43130/
    1280 x 720 - 446K
    keiron said:
    Hi
    Keiron
    i'll use the midi drum loop to figure out the tools to add to the midi importer
    the midi importer part already works,
    what's next is ... ways to make actors ( limbs or instruments ) move in sync
    i wont automate the whole animation process, i just want to give tools
    i wonder if there's a free poser/daz prop keyboard
    what's "piano format 0 and 1" ? midi instruments 0 and 1 ?
    Hi
    Standard MIDI Files come in two basic varieties: a Type 1 file, and a Type 0 file (a Type 2 was also specified originally but never really caught on. In a Type 1 file individual parts are saved on different tracks within the sequence. In a Type 0 file everything is merged onto a single track.
    Using type 1 would allow different instruments to be allocated to each MIDI channel
    In a Recording Program you could easily split each instrument onto its own Track
    keiron said:
    Hi
    it should work if the mf2t.exe ( very old midi-to-txt converter ) accepts it
    my script reads that txt file and only reads the
    tempo value which is needed to interpret the time stamps
    the program-change events which assign instruments to channels
    the note (On) events
    the other midi messages are ignored
    eventually i may include them
    well i spent some time modeling sit-position shorts for Amy since they initially suffered from poke-through
    1920 x 1080 - 1M
    1920 x 1080 - 983K
    arrrrrrrrrgh daz studio 3 crashed on me after saving an avi
    about an hour of finnicking lost ( oops maybe more than 1 hour !!!! )
    though i'll probably recover in 20 minutes
    see in the gif below
    i had the drum stick holding pose and drum placement
    i made Amy's foot follow the pedal movement by
    1 - creating a null node
    2 - using mcjParent to position the node exactly at the location of Amy's right-toes node
    3 - parenting the null node to the pedal
    4 - using mcjAutoLimb2014 and telling it make Amy's left toes node follow the null node
    in general i think it will go like this
    you'll specify a pose or rotation or a translation corresponding to no-note-played
    this pose can also be absent, so no animation will be addedwhen no note is played
    and you'll specify a pose or rotation or a translation corresponding to a note-played ( drum stick hit in the case of a drum )
    then you'll have a script that can build your animation either note by note or for the whole song
    in the case of the bass drum pedal, it could be done in one shot
    for the arms it can be more complicated since the
    1920 x 1080 - 823K
    500 x 281 - 300K
    Hi Casual Looking Good well done
    I downloaded MF2t , I see it's a DOS Prompt, so users may find this a problem to use
    Usage: mf2t [-mnbtv] [-f n] [midifile [textfile]]
    translate midifile to textfile.
    I wasn't sure how to use this either, I assume you add the name of the midifile and give the textfile a name
    Could I ask you a favor, for an example of how to use this use, and where the MIDI file should be put etc
    Re Daz Crash
    I've had this problem,in my case it was not enough Memory, so i've now got 24 Gig
    I've even got close to using all this on some renders
    Daz Studio also crashed on the 32 bit version as the video Avi render hit the 2 Gig limit
    It also crashed on the 64 bit version as the video Avi render hit the 4 Gig limit
    So I exported all the frames as single frames jpgs and rebuilt it using the free Virtual DUB , this worked OK
    To save time I also scaled down the number of lights I was using and used open GL for a render as the software one takes a long time
    the daz script will include a button that lets you specify where the mf2t.exe app is located
    this will only need to be done once
    then when you click the script's "Load midi" button, you will be able to specify which midi file you want to load
    the daz script will run mf2t.exe
    i only use the default settings
    so my command line will look like
    "C:\utilities\mf2t.exe" "C:\midifiles\jingle bells.mid"  "C:\midifiles\jingle bells.mid.txt"
    after mf2t has done its work, the daz script will load "C:\midifiles\jingle bells.mid.txt"
    this creates a node named midi, containing up to 16 channel nodes
    then there will be functions to transfer channel notes into animations
    ideally one could modulate the hammering action proportionally to the volume of the midi note
    attack, decay, sustain, release?
    in this drum stick animation
    there's 3 poses
    rest position,
    anticipation position
    hit position
    return to the rest position
    ( still trying to figure this )
    in the end, the important point is the hit position
    the preparation and the recoil motions can be interpolated
    960 x 391 - 279K
    400 x 300 - 352K
    Hi Casual
    I think your well on the right track
    Not forgetting, The MIDI info may also have after touch before the release
    Could use that for say a drum stick bounce - occilation before returning
    Thank you for all of you hard work it's much appreciated
    edited March 2015
    keiron said:
    Hi Casual
    there will be a standalone script to store on disk some motions
    for example, you can store the drum-hit motion
    notice that the shoulder, forearm and hand nodes are selected
    so only the poses of those limbs will be stored
    in this example it starts 5 frames before the Note-On event
    that's a 5 frames animation
    for the first 2 frame she pulls back/up the stick
    then the next 3 frames she brings it down
    the filename for this would be "Aiko3 Left Arm HiHat Attack"
    then you can store the drum release motion
    in my case it starts at frame 15 and ends 10 frames later
    it starts with the stick on the drum and ends with the stick pulled back/up
    the filename for this would be "Aiko3 Left Arm HiHat Release"
    there will possibly be an option to pre-program what happens during the note-sustain phase
    there will possibly be an option to store morphs
    ( like in the hyperactive video )
    https://www.youtube.com/watch?v=8IvHNzJhMA8
    or materials ( for lasers and color organs )
    once the motions are stored on disk
    there will be a script to connect the midi events to those stored animations
    i'm trying to keep this universal, who knows maybe instead of midi data it will be kinect, Wiimote or gamepad events
    871 x 642 - 254K
  • atticanneatticanne Posts: 3,009
    This is very exciting. I've added it to my "want to do" list.
    edited March 2015
    hoping to post at least a first version today
    if it's good enough to create an Amy drumming animation
    1920 x 1080 - 703K
    1920 x 1080 - 967K
    i wont release the midi-to-daz kit today
    but, it's in a good enough state that i'm able to produce a demonstration video today !
    and this marks the return of Misstick! who will share the hihat drumming with Amy
    1280 x 720 - 367K
    YAY !!!!!!!!!!!!!1
    Demonstration video
    https://www.youtube.com/watch?v=DAYlJYktNTk
    the midi to DS kit will come out this week i'm quite very sure but then again
    note that unless there's a mac version of mf2t.exe this will only work on a PC
    but but but, if you run the midi-to-Text converter on a PC, or have a friend do it for you
    then you could do all the Daz Studio animation on your Mac
    1280 x 720 - 435K
    Looking cool" Well done
    Love the Vids
    Great looking Drummer
    Now what about her friend playing keyboard !!
    Just a thought, I've used Animate2 to create blocks for specific animation sequencies
    in my case moving the hands left and right on the Keyboard and others for the finger movements
    The problem I found was I had no Midi Timing reference on the Animate 2 time line or on a normal time line so there was a lot of guess work
    Keep up the great work
    edited March 2015
    Love the Vids
    there will be the not-too-much-work possibility of automating the keyboard keys-down movements ( like a mechanical piano )
    visually you'll be able to see the keys being played, so you can position the hand in the vicinity of those keys
    a few frames ( ex: 3 ) before the key being fully depressed, then animating the 3-frames of the finger going down
    ( someday i may make a full pianist animator but i think that someday is not soon )
    well actually the finger-bend movement could be fully automated with the upcoming scripts
    but the hand position and side-side finger movements would need to be adjusted per chord/note
    over here
    https://poserdazfreebies.orain.org/wiki/Musical_Resources/Keyboards
    there's poser/daz compatible keyboards
    among them are even MIDI-animatable ones, when used in the context of Poser ( python scripts )
    personally i reworked Zippo's keyboard
    http://lab108.x0.com/lab108/inst.html
    i made each key, button, slider and wheel
    a separate prop part
    with its individual material
    eventually, with lab108's permission, that animatable version of his/her keyboard will be made available
    1920 x 1080 - 597K
    Thank you for all those links much appreciated
    i'll probably build a 1 minute animation
    of "My Sharona"
    Amy on drums,
    Misstick on keyboard for part of the melody i guess
    and the rest "played" by visual (light?) effects or robots or something
    if the scripts can help build this animation, they'll be good enough for the release
    for daz scripters
    here's a little script snippet that lists the instruments in a TXT file produced by mf2t.exe
     var file = new DzFile( "I:\\aoa\\midi\\pop\\msharona.txt" );
     file.open( file.ReadOnly );
     while( ! file.eof() )
      var str = file.readLine();
      if( str.indexOf( "PrCh" ) >= 0 )
       fields = str.split( " " )
       if( fields[2] != "ch=10" )
        p = fields[3].replace( "p=", "" );
        p = p.replace( "\n", "" );
        p = p.replace( "\r", "" );
        instr.pushIfNotExists( p )
     file.close();
     debug( filenames, instr );
    edited March 2015
    well evidently it will be more complicated than expected
    case in point .... handling the drums
    we need a sort of dope-sheet or track sheet
    1280 x 720 - 191K
    1916 x 798 - 558K
    edited March 2015
    here you see i selected only the cymbals
    and the "links" list shows only midi events for them
    this way we can quickly see that the two cymbals are never used at the same exact time
    so we could assign them to the same hand/stick animation
    fig. 3 : the channels get labeled with the first instrument ( program change ) encountered
    but each channel also has a "program" property
    so if there's more than one Program-Change for this channel,
    it is part of the midi-channel timeline
    444 x 260 - 52K
    1920 x 1080 - 507K
    1150 x 658 - 285K
    Hi Casual
    Hows it going
    Looking cool so far
    I found a set of MIDI Piano's from Content Paradise MIDI Bundle, that allows you to create a pose for animation
    but alas for Daz Studio it didn't work very well
    It comes with a program that you add a MIDI file, It then generate the Pose. It imported MIDI type 1 but wouldn't accept MIDI type 0
    You then add a MIDI piano Prop to the Daz Studio Scene and then import the created Pose
    ,you end up with frames for the song on the time line
    Each Piano Key has an object and they are also linked in Octaves
    So you can animate each key
    The piano did play, but The Keys that were animated were a bit dodgy, some stayed down, so it was nearly imposible to use
    I believe it's was designed mainly for Poser.
    Wishing you well with your project
    Kind wishes
    Keiron
