Would anyone that bought the Lightposts please show the wires? Thanks :)
AllenArt
[Would anyone that bought the Lightposts please show the wires?] What the title says :D Thanks!!
Edited for Please put your question in the post body and the title - Daz 3D Forums
They are street lights so there wont be any wires visible.
https://www.daz3d.com/lightposts--classical
the cables would be under the footpath for this type connected to the grid at the end of the street, usually found on streets with underground cables
or they are gaslights
streetlights that are mounted on domestic power poles have a secondary cable connected at transformers and look very mundane, used to use sodium vapor now LED
or were you referring to the filaments if just after gaslight era?
I assumed the OP was asking for renders of the wireframes...
I didn't purchase, unfortunately, but maybe OP can clarify.
Yes, I meant wireframes ;). I thought I saw some artifacting in the promos and wanted to check. Thanks :)
ah now it makes sense
as an Australian I had thought maybe some street lamps overseas could have powerlines I wouldn't know
LOL...no problem. And they're underground here too in the U.S. ;) I'm just used to calling wireframes wires :P
I like the lamposts, but saw a few things that looked like artifacts from topology. Wanted to see if it actually was bad topology or just maybe bad smoothing angle before I bought them :P
Be sure and check the mesh density, too. Daz+ has a habit of offering products with insane and unnecessary mesh density.
