light dome pro-r
alanthompson9187alanthompson9187 Posts: 134
purchase light dome pro-r and get a black blank screen when i load it, using 4.7 anyone get the same or a answer on how to use it, watched the authors video but still won't work.
  • TaozTaoz Posts: 10,384
    Did you install the files in Public/Public Documents/My DAZ 3D Library? There's also a DAZ Library under [Username]/Documents and I was confused by that in the beginning and installed stuff there and couldn't find it in DS. There may some things that don't work either even if you can find them in DS, if you install them there.
    But I did install LDP-R in the correct folders, and it worked right out of the box.
    1054 x 765 - 215K
  • alanthompson9187alanthompson9187 Posts: 134
    Thanks for the reply.. will look into this... i used the download manager to do the install... everything appears to be in the content folder when using through the software when you double click the load scene button all i get is black screen, then the backgrounds don't load in.
    THANKS FOR THE REPLY
