• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
diffeomorphic g8.1 HD textures wrong
3dQuill3dQuill Posts: 35
September 2022 in Blender Discussion
Hi, I've been trying to figure out a problem for some time now. I narrowed it down to the 8.1 HD export to Blender. When I export an 8.1 character to blender, it imports fine with diffeomorphic. But when I try an 8.1 HD mesh at resolution 3 with absolutely nothing else (no eyelashes, geographs, nothing) the textures are off. Only on the HD mesh and only 8.1. Does anyone know why? Looks like the UV maps are on top of each other. Now that I'm writing this, I wonder if I should uncheck "merge UV's"? It never gave me problems before though.
  • PadonePadone Posts: 4,015
    September 2022 edited September 2022
    Merge uv layers in easy import may not work fine in all cases. It is better to merge uvs by hand if you must, but in blender there's no need to merge uvs it is mainly intended for exporting to games.
    Let me know if this works. Otherwise please describe the exact steps to reproduce the issue, possibly with pictures.
    edit. p.s. Just tested Victoria 8.1 HD and she works fine here.
    Post edited by Padone on September 2022
  • 3dQuill3dQuill Posts: 35
    September 2022
    Ok, this is what I'm trying to accomplish and this is what's happening.  For the record, I'm using https://www.daz3d.com/mso-vix-hd-for-genesis-81-female but it happens with all the 8.1's I've tried.  I want to attach the Golden Palace gen to the HD mesh.  So I export to blender from Daz with the gens first, then I delete everthing, except the model, and export resolution level 3 HD to Blender.  In Blender I import the first regular export/with gen using diff, then import the second mesh/HD/no gen.  The HD mesh's textures comes in like this.  Left low res with gen, right HD with no gen.
    6600 x 4100 - 2M
    September 2022
    If you're exporting a true HD mesh then you need to export the HD uvs in the export dialog. Beware that HD geografts will not export the HD uvs, and this is a known limit. You said you export the HD figure without geografts though, so this shouldn't concern you. Also golden palace is not HD.
    Anyway if you want to "attach" golden palace to the true HD mesh one quick way is to apply multires. Works fine here with Victoria 8.1 HD and golden palace.
    steps:
    1. import the HD mesh with multires
    2. merge geografts
    3. apply multires
    September 2022
    I'll give it a try when I get home. I wasn't aware that I could merge geografts like this. Thanks. One more thing, soft body sim isn't being created on the true HD mesh. Two collections of mesh get imported and the non-hd mesh will have the simulation.
    Yes, I see that if you use easy import then the geografts and softbody are only done on the base figure, not on the HD figure. I don't know if this is a limitation or a bug, I'll report to Thomas.
    Anyway if you use the standard import you can then add the geografts and softbody to the HD figure.
    https://bitbucket.org/Diffeomorphic/import_daz/issues/1167/
    edit. Thomas fixed it you can get the last commit.
    September 2022
    Thanks so much.
    September 2022
    So here's an update. After failing at several attempts to import the Vix HD model with the correct textures even with everything deleted, I saved the morphs, opened a new scene and created her again. It imported into blender perfectly. My original file must have gotten corrupted, because the last 2 imports didn't even create an HD collection in Blender. But everything is working now. Thanks for all the help. I haven't tried the soft body on HD mesh yet. Trying it tonight.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
