My Genesis 8 and Genesis 8.1 Female Figures Are Loading with Custom Morphs
Epic82
When I load both Genesis 8 and Genesis 8.1 Female figures, Daz, for some reason, loads these figures with custom morphs on them. The morphs are from Priya for Genesis 3 Female and a few other details, that I converted to Genesis 8 Female with Discobob and Zev0’s XTransfer - Genesis 3 to Genesis 8 Converter. I converted this character a long time ago. You can see the corrupted figure in the first screenshot I’ve uploaded. This morph has merged with other Genesis 8 and Genesis 8.1 figures, as you can see in the second uploaded screenshot. The figure on the left is Gia 8, and the figure on the right is Victoria 8. Priya is such a unique character the difference between the original characters and the corrupted characters in the screenshot is easy to see.
However, some of the Genesis 8 female figures that I have saved as actors, like the Freja 8 and a Rune 7 figure I transferred to Genesis 8, load fine without any of the Priya for Genesis 3 morphs on them. I read this thread and I’ve done the process of zeroing all the dials that shouldn’t be dialed up on the base Genesis 8 female, and I saved the modified assets for Genesis 8 female. But it still loads with the custom morphs. I went to My Library\data\DAZ 3D\Genesis 8\Female\Morphs/Daz3D/Base and found XT Priya Body, and I deleted it. You can see this file in the third screenshot. But deleting this file does nothing to fix the problem. Does anyone know how I can fix this? I think this problem began only a few days ago when I attempted, for the first time, to change a wearable, a dagger from Britech’s Aten Weapons Collection, into a prop, and vice versa. But I’m not sure.
I’m sending this early in the morning, and I might be asleep by the time someone responds. But I’ll definitely respond later today.
It isn't enough just to zero the dials, one must also memorize the figure, which makes the zero the default value for the dials.
Working instructions;
To fix any ill-behaving (non-zero default value) morphs, do as follows;
1. Open DS and load "Genesis 8.1 Basic Female" (to an empty scene)
2. Right Click at Parameters Tab->Preferences->Choose "Show Hidden Properties" (part 3 zeroes only 'visible' dials)
3. Right Click at Parameters Tab->Zero->Zero Figure (Zeroes the value of all the 'visible' dials)
4. Right Click at Parameters Tab->Memorize->Memorize Figure (Sets the current value of all the dials as their default value)
5. Edit->Save As->Support Asset->Save Modified Assets (Writes the changed default value to the morph files that were changed)
When saving "Modified Assets" DS shows a dialog and asks for confirmation;
"The following file(s) will be permanently modified:" - "Accept/Cancel" - Choose "Accept"
Thank you so much PerttiA! Your instructions helped me solve the problem.
