WCIF Compression sleeve for g8 female (also Olympic related items)
edited September 2022 in The Commons
I'm looking for a compression sleeve that a track runner would wear, as displayed in attached photo, for G8 female.
Thanks in advance
(Update: I did some searching and there really is a lack of items for what I wanted to render.  Thinking Olympic Track and Field setting.  Cannot find stadium or track.  Did find this one dated item for props but its old v4 days: Athletics Props Set | Daz 3D .   So I'm looking to find the items necessary to render a Track and Field competition.)
Post edited by reine_law_0cc9bf9349 on
  • Updated request.  Still looking on my end.
  • felisfelis Posts: 5,931
    How many details do you need?
    It is fast to model something like that, if applying a shader is sufficient for the material.
  • PixelSploitingPixelSploiting Posts: 898
    Two freebies from dA that might be close enough if you don't mind small differences in shape:
    https://www.deviantart.com/amyaimei/art/Endorphin-Sport-Outfit-Converted-for-Genesis-8-1-876298144
    https://www.deviantart.com/amyaimei/art/Color-Block-Bikini-for-Genesis-8-1-Female-889332623
    You'll have to come with a suitable texture, though.
    No sleeves, though.
    A sleeve could be made with a geoshell, though.
    Post edited by PixelSploiting on
  • I havent seen any compression sleeves here, but. If you have gloves that are arm length, you might be able to hid the hands portion to get the ame look with the right shaders. I was thinking because of the micropressure in the Umbra Outfit set you might be able to get the right look with maybe a spandex shader added. Ill have to check my library to see if I have any similar sleeve/gloves that may be part of a set that match it more without having to remove some part of the sleeve/glove.
    Something like this?
    1200 x 900 - 2M
    Exactly!  Where did you find or make this? If you made this, where may I perchance find it :)
    As mentioned higher up, modelling something like that is easy.
    The hard part is getting them properly packed for DS.
    I will clean them up, and get it packed. The shader will be simple, so you might apply your own.
    This is what it looks like now.
    So  try this.
    Let me know if issues.
    1200 x 900 - 2M
    zip
    zip
    G8F_sportssleeves.zip
    4M
    So  try this.
    Looks great!  Im about to travel for long weekend but will mess around with it early next week and post my render.  Thanks for help!
    So  try this.
    Did a quick render and threw on a shader....looks great thanks!
    995 x 873 - 348K
  • nabob21nabob21 Posts: 1,054
    There is a track and field set for Poser by 2nd_World over at Renderosity. His products generally work fairly well in Daz Studio but you may need to tweak the materials. Do a search for 2nd_world to see his store.
    Also richardandtracy has made a number freebie of track and field poses for G8 as well. Do a search for richardandtracy in the Rendo freebie section. They have made a lot of very nice pose sets available for free.
    Post edited by nabob21 on
    Thanks.  I found the track freebie.  I'll see what else I can find.  Kind of suprising no one released an item based around this.
