Creating Reflective Surfaces?
PVGamesPVGames Posts: 68
Hello,
I was just curious about something: How do you create a reflective surface, like a mirror or glass pane? Any suggestions/tips are appreciated. Thanks!
  • pwiecekpwiecek Posts: 1,540
    You have to use raytracing.
  • Eva1Eva1 Posts: 1,249
    SuperGJ said:
    Hello,
    You shouldn't need to adjust your raytrace settings, depending on what you are trying to achieve. Some settings are given in this tutorial:
    http://www.art-tlc.com/mirror3.html
    an old forum topic gives some good tips too:
    http://forumarchive.daz3d.com/viewtopic.php?t=16922
    You can start by increasing the reflection setting of the surface under the Surfaces tab - increase that to 100% and see how that looks, you may need to adjust your lighting and don't forget to put something in the scene to reflect.
    I hope that helps.
  • 3dcal3dcal Posts: 178
    edited August 2012
    removed reply......wrong forum....sorry.
    Post edited by 3dcal on
