Supersuit 2 for Gen 2?
2»
    In my opinion the G-Suit 2 makes a rather good supersuit. It's superior, in a sense, as it has a lot of HD morphs which can tidy up the edges and add some nice subtle details too. It's designed for females, but it autofits nicely on males and isn't overly gender-specific in its material zones.
    As for using the ACTUAL supersuit on Genesis 2, it works fine for the most part. I've had no major issues with fitting or posing, but it might be different with some of the more extreme morphs.
  • KeryaKerya Posts: 10,943
    Well - for giggles I put it on Genesis2 - The Girl 6.
    I think for an example of extreme morphs she works well.
    I had to adjust one or two zones with a bit of expand on the chest - but that was all.
  • kyoto kidkyoto kid Posts: 42,127
    ...my only issue with the G-Suit 2 is it is HD which requires more from system resources.
    There is also the original G-Suit Bodysuit for Genesis which is currently on Fastgrab at 70% off. Since it is already made for a weight mapped figure I would imagine it would retain it's morphs after autofitting.
  • Steven-VSteven-V Posts: 727
    I agree with this. I have been VERY happy with G-Suit 2 and also found it to be superior to Supersuit in many ways -- probably the main way is that the "sections" of it make more logical sense than the ones in the Supersuit. For example, you can create a "leotard" shape with G-Suit 2, which you cannot do unless you use an opacity map with Supersuit because of the funny shapes around the thighs and hips.
