Supersampling with DazStudio
Is it possible to set some sort of supersampling directly through DazStudio? For example setting render resolution to 120%, to get sharp render despite rendering at lower resolution.
I know that you can simply render at higher resolution and then downscale using 3rd party software, but I just wanted to ask is it humanly possible directly with DazStudio.
I couldn't find anything in the render settings, for Iray, that would enable this, nor any documentation regarding it.
If your looking for a sharper render, one thing you can do is change the filtering in the Iray Render Settings--->Filtering--->Pixel Filter
Change it from the default gaussian to Mitchell and change the Pixel Filter Radius to .8 or .9
If anything, the opposite is happening. Iray is going to use (or is already using*) nVidia's other technology, DLSS. Which is rendering at a lower resolution and using the Tensor cores and AI to scale up to full size.
* - I think Iray used DLSS in 'Realtime' mode, though 'Realtime' mode was removed over a year ago.
