Supersampling with DazStudio
Is it possible to set some sort of supersampling directly through DazStudio? For example setting render resolution to 120%, to get sharp render despite rendering at lower resolution.
I know that you can simply render at higher resolution and then downscale using 3rd party software, but I just wanted to ask is it humanly possible directly with DazStudio.
  • I couldn't find anything in the render settings, for Iray, that would enable this, nor any documentation regarding it.
  • GranvilleGranville Posts: 702
    If your looking for a sharper render, one thing you can do is change the filtering in the Iray Render Settings--->Filtering--->Pixel Filter
    Change it from the default gaussian to Mitchell and change the Pixel Filter Radius to .8 or .9
  • prixatprixat Posts: 1,630
    If anything, the opposite is happening. Iray is going to use (or is already using*) nVidia's other technology, DLSS. Which is rendering at a lower resolution and using the Tensor cores and AI to scale up to full size.
    * - I think Iray used DLSS in 'Realtime' mode, though 'Realtime' mode was removed over a year ago.
