hd morph dont work fine
Hello everyone together
I have created an hd Genesis 8 from the tutorial"How to create your own HD Morphs" unfortunately the figure deforms despite bones, what can I do to correct the error.
thank you very much for your help andreas
  • Please put the Viewport into a non-textured Drawstyle if you are going to show a nude figure.
    You cannot create true HD morphs, only PAs have that tool and only for use in creating content for the Daz Store
    The issue with your morph is that you have changed the proportions, so the model no longer lines up with the rigging. Edit>Figure>Rigging>Adjust Rigging to Shape should fix that, then you need to do an ERC Freeze to link the adjustments to the morph (assuming you have not already used the Freeze function, in which case you will need to find the existing link in the Property Hierarchy pane, right-click on it, and ERC Bake to turn it back into raw values which can be frozen along with the joint adjustments).
  • Thank you for the quick answer i will try Andreas
  • Is there a way to make a hd morph (sub dev level 2-3 ) in zbrush and bring it back to genesis 8 ?
    Andreas
  • AscaniaAscania Posts: 1,856
    Andreas
    Yes. If you are a Published Artist here.
