Animating a growing plant - Ideas?
I am making a fantasy Carrara plant (custom leaves and fruit).  I want to animate the plant growing from a sapling with no leaves and green stem to a mid-life taller trunk with more leaves and finally to a full grown tree with ripe fruit.  The shader animates fine (changing trunk from green to brown), but the tree modeler settings don't seem to be animatable (trunk length, weight given to leaves/fruit,...).
a - what can be animated for Carrara plants, and what cannot?  Is there a guide somewhere?
b - if you were going to animate a growing plant that produces fruit late in the animation, how would you do it?
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,454
    I think it would need to be converted to a vertex model
    then create morph targets
  • DiomedeDiomede Posts: 15,401
    Thanks for the suggestion.  Too bad,  I guess I will use a different method to convey passage of time, perhaps using dissolve transitions.  Thinking cap on.
  • RuudLRuudL Posts: 227
    edited August 2022
    a - If you want to know what can be animated of any object, including plants, you simply have to unfold the object listting (Universe, Master Objects and Master Shaders) in the sequencer.
    Post edited by RuudL on
    edited August 2022
    b - I would try this with a PyModifier ( part of PyCarrara ). Start with an small invisible fruit object, make it visible at a given time and after that gradually adjust the scale and shader.
    1224 x 1183 - 320K
  • HeadwaxHeadwax Posts: 10,456
    Hi ted, there was discusion similar to this on the old forum ? about animating a vine - can't remember what the answer was
    I just tried animating a replicated thingy by changing the shader - no joy
    You can, however, animate splines if you wanted to go that way ;)
    ah there's leaves blowing ... not quite the same as growing!
  • Steve KSteve K Posts: 3,474
    That was my first thought, as always slanted by the 48 Hour Contest - time is of the essence.  The dissolve can be done in seconds in the video editor.  One example (starts ~1:05) from Howie's great products for Carrara:
    Also, I realize this is probably not what you're looking for, but a Particle Illusion 2D overlay on any image or video.  Starts a few seconds in:
    Thank you for the great information, RUUDL, Headwax, and SteveK.  The screengrabs and video examples are especially helpful.
  • DUDUDUDU Posts: 1,945
    Hi Ted!
    I remember using 'VUE 5" to make these animation of plant: see at the minute 6:40
    https://www.dailymotion.com/video/xehl9h
    DUDU said:
    Hi Ted!
    Great animation!  Thanks for posting.  How did you do the flaming meteorites?  Another issue I am trying to figure out is the fire breathed by a dragon.
    Great to see you posting again.  Hope you are well.  What projects have you been working on?
    DUDU said:
    Hi Ted!
    Good point, DUDU.  I still consider VUE one of the best 3D animation programs, but recently got more into DS/Iray to use some high quality products.  Carrara, VUE, DS, Poser ... >B-O
    Dudu, that is one impressive animation yes
  • StezzaStezza Posts: 8,861
    +1 on that yes
  • Bunyip02Bunyip02 Posts: 9,288
    Syezza said:
    +1 on that yes
    +2 yes (Got a long way to go on my animations !!!!)
  • DesertDudeDesertDude Posts: 1,239
    DUDU said:
    Hi Ted!
    This is exquisite! And the musique original is beautiful!
     I was able to make a crude quick test of 2 generations of branches growing and leaves growing in succession, with a little overlap. Your animation would need much more care and planning, but anyways, for lack of a better term this is a "stop motion" animation. smiley
    https://youtu.be/8zHYPfv-2ZA
    This is just the generic plant dropped in. I didn't animate the trunk. In the Experts Tab, I dialed back the Length Ratio in the Gen1 Branches, and udjusted their Start and End angles so as I increased the Length Ratio, they would grow up and fall down outwards and give a little bounce.
    I also changed the Leaf Size from 0 to 1 and gave them a slight Twist.
    So, with each change I made a render and gave them names to be used as an image sequence and then rendered out a final movie.
    Even though you can add objects as leaves, I can't get animations or morphs added to those leaves to work when added to plants. Has anyone ever tried before and had success?
    I tried both morphs and some simple keyframe animation added to a custum leaf, exported and saved all internally in the file. But when added to the tree, and I move the playhead down the timeline, nothing happens. sad
    I was hoping that might be an easy way to finesse the developing leaves and eventually the fruit.
