V4 --> G2F shoe ruckus
rumpotrumpot Posts: 96
I am trying to follow this
when I first import the shoes it sort of lines up(pic 1)
then when I auto fit V4-footwear the shoes move to the middle(pic 2)
and I cannot follow the tutorial above, any suggestions?
  • Richard HaseltineRichard Haseltine Posts: 111,110
    Which shoes are they? Are you sure they were made for V4?
  • rumpotrumpot Posts: 96
    Yes they are for V4
    link
  • DigiDotzDigiDotz Posts: 515
    The following works for me
    pose genesis
    convert shoes to weightmapping
    transfer utility Genesis Source Shoes as target (no fitto)
    Select Genesis than Ctrl Select shoes
    Joint editor>edit>transfer rigging figure space
    Select only the shoes
    right click in viewport
    memorise figure rigging
    hope it works for you
    Looks like you're not unfitting them after you run the transfer utility? You need to do that before the repositioning/ transfer rigging step.
    edited February 2015
    The pic 2 happens before all that, It makes no difference if I cancel out of the auto fit or auto fit, the shoes always move to that position.
    So I can not get past step 3 of the tutorial
    Post edited by rumpot on
