Anatomical Elements and Foreskin
Hi,
I want to ask about how to control foreskin on uncircumcised anatomical elements for G8M from Michael Pro Bundle ? Is there an option to move the foreskin back and forth, because I'm unable to find it or do I need another tool for it ?
    You are out of luck here at DAZ, they don't really focus on any detail concerning genitals, not family friendly enough, LOL Try renderotica
    Yep, in Dazland, one doesn't have access to those elements prior to ones 18th birthday and even then one needs to buy a bundle of things to get one on the side. One also must have skin to wrap it in or borrow one from a fellow citizen - No playing with it or it will fall off cheeky
  • ecks201ecks201 Posts: 490
    edited August 2022
    Nope. It's either on or off with the Daz ones.
    You can buy replacement genitalia from certain other stores.
    The absolute power of an alternative product is that you'll get 21 separate foreskin controls, as opposed to the On/Off on the ones you currently have.
    Post edited by ecks201 on
  • FauvistFauvist Posts: 2,290
    Don't you mean forsaken?
  • nemesis10nemesis10 Posts: 4,011
    Well, Soto's Maxx has a "foreskin rolled" morph in the Daz store.  I think Tempestra's gen morphs at Renderosity might suit your needs with circumcised, uncircumcised, and "halfway" morphs.
  • Avid RendererAvid Renderer Posts: 1,213
    Yes (Maxx)! used it in my deviant works.
  • lzh35925lzh35925 Posts: 25
    I was aware about Maxx, but it goes only half way down and if you pull it back it disappear. It's kinda weird morph at least with original male genitalia for G8M. It's a shame they didn't finished the foreskin, because it would be a better business decision, if they do.. well, in any case, many thx to everyone for answers, I try some alternative..
  • CybersoxCybersox Posts: 9,924
    There are also some excellent morph sets for the DAZ gens available on Renderosity if you don't want to deal with the explicitness of Renderotica.  For example, Tempesta3d has a standalone set for the G8M gens called Manly that includes a number of foreskin shapes and other morphs, and that vendor sells several character sets that include similar morphs.  The selection at Rotica is, of course, a lot bigger (pun NOT intended) but, yeah, there are things there that some folks would rather not see (and again, pun NOT originally intended, but what can ya do?.)
    Manly is the Tempestra Renderosity morph set that I mentioned.  The Maxx consists of multiple morphs including "rolled"  which partially exposes the glans, a specific uncircumcised control, and a morph to add details to the uncircumcised morph.
  • zombietaggerungzombietaggerung Posts: 3,942
    edited August 2022
    There's also THIS freebie on deviantart. It has some foreskin morphs for the default g8m gens.
    Post edited by zombietaggerung on
    And there's also Jepe's Roderick for Diego 8, who comes with
    • 14 HD Adjustment Morphs
    • 14 HD Full Morphs
    • 21 Easy Pose Dials
    but none for moving the foreskin forth and back. In the end one probably needs several products to achieve exactly what one wants... For adjusting the base DAZ male anatomical elements some products by LexaKiness at Renderotica might be usefull
    thx, for more answers!
    nemesis10: Manly looks interresting, I probably give it a shot!
    zombietaggerunj: this one literally deform the model, I can't use it
    maikdecker: I actually own Jepe, but he can adjust only the genitals, not the foreskin
  • Matt_CastleMatt_Castle Posts: 3,251
    The default Daz genitals are very much of the scope that "There's something there for artistic nude renders", they're not made (or built in a way they can be converted) for finer posing. What you want would be far better served by a third party product.
    As others have said, I recommend you look at the Renderotica store. Personally, my recommendations in terms of cross compatibilty of assets and posing support is to look at products from the vendor Meipe.
    edited August 2022
    Yeah, at least there's no morphs to tiddle with the foreskin, which I mentioned the need to use several products to achieve full functionality of the anatomical elements..
    Meipe's products are great (and I own a couple...) but you always work with a "replacement anatomical element" (which offers tons of options..) which usually needs to adapt the torso textures to apply them to the anatomical elements. So at least for figures that come with their own dedicated textures for the DAZ anatomical elements I rather use the LexaKiness mophs for the DAZ anatomical elements...
    Post edited by maikdecker on
    Matt_Castle: I've done my research and end up with the same conclusion. It will be probably 2 products instead of 1, but it looks like they worth it
    maikdecker: I tried Manly, it has desirable effect, but it's not perfect, but honestly, with little bit of tweaking with camera, I can manage it
    One additional question: I used the original male genesis 8 anatomical elements, but it looks like it's happening with 3rd party products as well, when I hide or delete the anatomical elements, the whole section disappear and there's a big hole, where the elements were. How can I restore my model to not have elements, but be whole again, pls ?
    If you want him to wear clothing and still have his masculinity somewhat in tackt, set the scale of his masculinity to 30%, this doesn't look pretty as it creates an indentation to the hip, where hia tools will be hidden, but it does allow having both, the dangly bits and clothing to be worn at the same time.
    Installed the morphs, loaded a couple different G8M figures... and can't find anything except the half-hidden morph.  Looking in the actual dir paths in the zip file, I see a lot of morphs starting with the name MCM, but when I select the gens, I can't find anything in the morphs under Parameters tab with the that in the name, and there isn't a MediAsylum sub-group of morphs showing.  It is clear I did install the morphs, because if I go into My DAZ 3D Library, I can find the actual files sitting in ...\data\DAZ 3D\Genesis 8\Male Genitalia\Morphs\MediAsylum\Advanced G8MGen but nothing is showing up in Daz Studio.  Am I missing something?  0o
    edited August 2022
    They show up for me under Advanced Control, with the gens selected:
    This is just a small part of the list obviously.
    397 x 342 - 42K
  • Ah, there it is...  >>giggle<<  I guess what threw me for a curve is that the slider names left the MCM stuff off, and it was all in a generic-sounding category in there.
  • marblemarble Posts: 7,500
    Just to quell any doubts about matching textures - I have never had a problem getting the Meipe gens to match the character skin. There's a good blend region which means ther's no sharp colour or texture transition and then it is just a matter of picking the closest of the available texture shades and tweaking in the surfaces panel (usually just a matter of adjusting the Translucency value).
    Well, I guess they are ready to potty train if nothing else.
  • CHWTCHWT Posts: 1,191
    That's one small step for G8M, one giant leap for naughty renders.
