New - B to Daz
2»
  • anikadanikad Posts: 1,919
    edited August 2012
    You have bought Victoria 5 and clothing that is for Victoria 4. When you look at the item listing scroll down to the additional information tab, and look to see what the compatible figures are. For clothing to work easily on Victoria 5 the compatible figures must include Genesis or Victoria 5.
    Out of the outfits you are interested in the only one that will work easily with the set up you have is Liquid Halo on Sky 16 for Genesis
    http://www.daz3d.com/shop/liquid-halo-on-sky-16-for-genesis
    Post edited by anikad on
  • wiibbwiibb Posts: 0
    Yeah I got them yesterday when I first downloaded Daz just to play around with. I have seen today that different models require clothes that fit them..... Just a little to hasty to play with the software :)
    I am an engineer and use Inventor, Auto CAD, Keyshot and Photoshop for my work but would like to start to use Daz to include in my renders of my CAD work just for a hobby is there any other software that I should look into to help with the renders from Daz?
  • fixmypcmikefixmypcmike Posts: 19,738
    Most of those are for V4 rather than V5. You can use them on Genesis using Autofit -- some items work better than others, and shoes in particular are difficult. Autofit is built into DS4 Pro -- if you don't seem to have it, you need to go to Help > Register DAZ Studio and put in the free Pro serial number.
    So either Autofit or buying Victoria 4 will allow you to use After School, SD4, and Rogue for V4.
    Liquid Halo for Genesis will work on Genesis (including V5 and other Genesis morphs).
    Rogue-Latexlove is a texture set for Rogue.
    Prophecy for Shadowcaster is a texture set for Shadowcaster http://www.daz3d.com/shop/shadowcaster
    which is also a V4 item.
    Neural Ghost is a texture set for the Aiko 3 Catsuit. Aiko 3 is another separate figure -- you can either use it on Aiko 3 (she is free as part of the Anime Star Fighter Bundle http://www.daz3d.com/shop/anime-star-fighter/ ), or if you buy the A3 Shape for Genesis http://www.daz3d.com/shop/a3-and-h3-shapes-for-genesis that also adds A3 to the Autofit options.
    Thanx guys this is really great info that you have supplied and do really appreciate the time you have spent on helping and answering my questions.
    :P
    Hi Guys so I need to get v4 then for those outfits!
    Is it the one that cost $99 or another one I would need to purchase?
    If possible could you give me the link to the v4 so I know I shall be buying the right one for some of them outfits?
    Thank you
    :P
    The minimum requirement is the base figure: http://www.daz3d.com/shop/victoria-4-2-base
    Depending on what your interests are, you may find it worthwhile to get the Pro Bundle: http://www.daz3d.com/shop/victoria-4-2-pro-bundle
    or the Pro Suite: http://www.daz3d.com/shop/victoria-4-3d-model-pro-suite
    However, you can still use them on Genesis with the Autofit capability in DS4 Pro -- you can try them out and see how well they convert.
    Thank you very much for the info
    :P
    Hi Guys, I have bought what you suggested http://www.daz3d.com/shop/victoria-4-3d-model-pro-suite for me to start with Daz. I have installed a lot of the files I downloaded but still having problems again with some of them as they are not going to the right path..........
    I have tried to put in the path that was suggested in earlier posts but still not working?
    Can you please help me over come this problem to get me started with Daz?
    Thank you.
    :P
    Which parts are giving you problems?
