having exporting troubles with Temple of Anubis
in New Users
https://www.daz3d.com/the-temple-of-anubis
Specifically the Anubis statues. I've gotten everything else to export properly but when I try the statues, only the props export. Not the body. I asusme I'm doing something fairly obvious wrong?
Export to what?
and in what format?
try the Poser versions maybe, the DAZ studio one could be using instances
I don't own it but if something has a Poser version like this says it has, I usually export that.
I've tried DAE and obj so far. Same beavior for both.
Still not quite sure why this isn't exporting correctly unlike the other props. I've attached the file. Any help/conversion appreciated. Thanks!
You still are not explaining what you want to export it to which program
Is this Anubis a prop or a figure? Is it relient on anything else? Genesis 2 maybe?
