having exporting troubles with Temple of Anubis
https://www.daz3d.com/the-temple-of-anubis
Specifically the Anubis statues. I've gotten everything else to export properly but when I try the statues, only the props export. Not the body. I asusme I'm doing something fairly obvious wrong?
    edited March 2020
    Export to what?
    and in what format?
    Post edited by Chohole on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,685
    edited March 2020
    try the Poser versions maybe, the DAZ studio one could be using instances
    I don't own it but if something has a Poser version like this says it has, I usually export that.
  • Chohole said:
    Export to what?
    and in what format?
    I've tried DAE and obj so far. Same beavior for both.
  • Still not quite sure why this isn't exporting correctly unlike the other props. I've attached the file. Any help/conversion appreciated. Thanks!
    91 x 91 - 5K
    You still are not explaining what you want to export it to     which program
  • Is this Anubis a prop or a figure? Is it relient on anything else? Genesis 2 maybe?
