Hair refits
NosiferretNosiferret Posts: 353
I've got a M4 hair item that I want to use on Genesis2 male but it will not follow the character. I've tried everything I know [which isn't much regarding Studio..I'm a newbie] and I can't find any refits for old hair items converting to the G2 models. The hair in question I am trying to use Feather Hair for M4.
  • barbultbarbult Posts: 27,400
    How did you put the hair on Genesis 2 Male? Did you use autofit to fit it to the character, or did you parent the hair to the character's head. I don't have that particular hair to try.
    As it's a prop hair rather than a conformer, you're probably better off parenting it to the head and using the morphs.
  • FSMCDesignsFSMCDesigns Posts: 12,855
    Here is what works for me on any hair not made for the figure you are using. If you have your figure posed, save the pose, then zero the figure. Add the hair, do not autofit and it should be close to the correct position, adjust, add a smoothing modifier to the hair if needed to collide with the figure to get a perfect, snug fit. Then parent the hair to the head and reapply your saved pose to the figure and viola!
