Why is my scene always lit.
Been trying to learn more about lighting. But I notice that on the you tube guides, the scenes are not lit when environment is set to scene only and the figure is like a black shadow.
I do not get that. even when the environment is set to scene only and there ae no light sources, or camera, only the figure, it remains lit.
Any help on this.
  • butterflyfishbutterflyfish Posts: 1,500
    Do you have the camera headlamp on or set to auto? It's under headlamp in the camera panel.
  • don_iliffedon_iliffe Posts: 10
    Nope, there are no cameras or lighting set at all in the scene
  • nemesis10nemesis10 Posts: 3,889
    edited July 2022
    Try the default camera and turn off the headlight.... Parameter Tab > Default Camera > Headlight > Off
    Post edited by nemesis10 on
    OK, I knew it was going to be something simple. Thanks for that, solved it nicely
  • Richard HaseltineRichard Haseltine Posts: 109,160
    You don't need to use a camera, there is a global switch for the Headlamp in Render Settings>Editor tab.
