Why is my scene always lit.
Been trying to learn more about lighting. But I notice that on the you tube guides, the scenes are not lit when environment is set to scene only and the figure is like a black shadow.
I do not get that. even when the environment is set to scene only and there ae no light sources, or camera, only the figure, it remains lit.
Any help on this.
623 x 691 - 28K
423 x 277 - 19K
624 x 776 - 74K
  • butterflyfishbutterflyfish Posts: 1,832
    Do you have the camera headlamp on or set to auto? It's under headlamp in the camera panel.
  • don_iliffedon_iliffe Posts: 10
    Nope, there are no cameras or lighting set at all in the scene
  • nemesis10nemesis10 Posts: 4,056
    edited July 2022
    Try the default camera and turn off the headlight.... Parameter Tab > Default Camera > Headlight > Off
    Post edited by nemesis10 on
    OK, I knew it was going to be something simple. Thanks for that, solved it nicely
  • Richard HaseltineRichard Haseltine Posts: 112,078
    You don't need to use a camera, there is a global switch for the Headlamp in Render Settings>Editor tab.
