• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Convert Diffeomorphic Face Morphs to Pose Library?
GhoraxGhorax Posts: 8
July 2022 edited July 2022 in Blender Discussion
Is it possible to convert diffeomorphic face morphs to pose library poses in Blender?
After dragging a viseme or expression slider to the right, I can see the Rigify rig moving along with the mesh's face. Next, I select the affected bones in Pose Mode and try to add the new bone's positions to the pose library by hitting PoseLib Add Pose button > Add New.
Problem is that the Apply Pose Library Pose button, with the magnifier icon, does not do anything.
I have tried this same procedure both with the original face bones of the Rigify rig generated by the Diffeomorphic addon, as well as the additional bones that get added when you use the "Add Extra Face Bones" option, under Advanced Setup > Rigging. None seem to work for the pose library.
Curiously, when I manually move the poseable face bones of the rig, and then add the pose to the library, it works as correctly as intended. This seems to be a limitation of the morph sliders, not the rig itself. What is the workflow to make it work?
By the way, using the "Make All Bones Poseable" option before converting the DAZ rig to the Rigify one does not impart any difference that I have noticed, what does it do, exactly?
Also, the reason I am trying to achieve this is to be able to use the pose library for Lip Sync with the Rhubarb addon in Blender.
Post edited by Richard Haseltine on July 2022
  • PadonePadone Posts: 4,055
    This should be in the blender forum.
    In the daz rig there are some bones that are driven by other bones. For example the pectorals and eyelids. So these bones are driven in blender. This is why if you want to animate them you have to "make all bones posable". And also why to export a pose you have first to bake or keyframe the posable bones, as you discovered yourself.
    Be aware that of course the pose will be always relative to the driven position. That is, the pose comes after the driver.
    Post edited by Padone on July 2022
  • GhoraxGhorax Posts: 8
    July 2022
    Found this post by Thomas Larsson on blenderartists.org:
    The pose library only stores the bone transforms, I think. Not custom properties, i.e. the morph slider values.
    There are rumours that the pose library will get an overhaul in Blender 3.0. Perhaps this will make it possible to store properties too.
  • Richard HaseltineRichard Haseltine Posts: 108,949
    July 2022
    Moved to Blender Discussions.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
