• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Maya Discussion
OFFICIAL DazToMaya Bridge 2022 (SEPTEMBER UPDATE): What's New and How To Use It
danielbui78danielbui78 Posts: 333
June 2022 edited September 2022 in Maya Discussion
The September Update for the DazToMaya Bridge is now available on Daz Central and Daz Install Manager.  It has some changes to the UI which may take users familiar with the old version time to get used to.  Here's what's new:
  1. Updated to latest Daz Bridge Library v2.2
  2. Fixes morph undo bug (distorted faces on export)
  3. Geograft Material support
  4. Prelim steps for supporting Geograft morphs (exported blendshapes)
New Menu Location:
You will need to install the Maya Plugin using the new integrated Maya Plugin Installer.  Access this from the Advanced Settings box of the new DazToMaya Bridge UI.
How to Install the Maya Plugin
  1. The Daz Studio Plugin comes embedded with an installer for the Maya Bridge module. From the Daz To Maya Bridge dialog, there is now section in the Advanced Settings section for Installing the Maya module.
  2. Click the “Install Plugin” button. You will see a window popup to choose a folder to install the Maya module. The starting folder should be the default location for maya plugins and modules.
  3. On Windows, the path to install modules should be “Documents\maya\modules”. On Mac, the path should be “/Users//Library/Preferences/Autodesk/maya/modules”.
  4. For most Maya setups, you should be able to just click “Select Folder”. You will then see a confirmation dialog stating if the plugin installation was successful.
  5. If Maya is running, you will need to restart for the Daz To Maya Bridge module to load.
  6. In Maya, you should now see a “DazToMaya” tab in the Maya Shelf toolbar. Click this tab to find the DazToMaya options.
  7. If you have tabs disabled in the Maya Shelf, you may need to click the “cog” icon and select “Shelf Tabs” to find and select the “DazToMaya” tab.
  8. From the DazToMaya tab of the Shelf, you should now see an icon for “DAZ IMPORT”. You are done installing Daz To Maya Bridge!
  9. If you recieve an error when trying to click the "DAZ IMPORT" icon, make sure you have PyMEL installed.
You can find more information about the updated DazToMaya Bridge with these resources:
  • DazToMaya Bridge on Github
  • Installation Instructions for DazToMaya Bridge (Githhub)
  • How to use the DazToMaya Bridge (Github)
  • Download the latest updates and bugfixes (Github Release Page)
  • DazToMaya FAQ (daz3d.com)
How to Install DazToMaya Bridge v2022
More tutorials coming soon...
Post edited by danielbui78 on September 2022
  • AsariAsari Posts: 703
    June 2022
    Thank you for the update!
    Does this mean you can export a figure in subdiv1 or higher to Maya and all morphs that you choose to export are exported in subdiv1 or higher as well - meaning you could export HD morphs?
    If yes - wow. It's very well possible to do all of this already but not with a one click solution and you need to setup a couple of things yourself. If the DtoM script has all these steps scripted - that's a gamechanger for sure.
  • videoninja719videoninja719 Posts: 344
    June 2022
    in maya 2023, daztomaya plugin is not appearing
  • mgr0704mgr0704 Posts: 37
    June 2022
    Trying to get Daz to Maya Bridge working in Maya 2022. It says to install it to this directory “\Users<username>\Documents\maya\modules” from DAZ Studio. There is no "modules" directory there. Any clue as to what I am missing?
  • autodolorautodolor Posts: 70
    June 2022
    Just put in Documents\maya\mayaVersion\modules, or create the folder...
    June 2022
    By the way, I have installed the new plugin from about 3 days ago, and when I pass it to Maya, and then to MotionBuilder, to filter it better, the fbx generated from "python tools" in MOBU version 2013 of fbx, Daz gives me a garbage of geometry! :D
    June 2022
    Thanks, autodolor, that worked!
  • danielbui78danielbui78 Posts: 333
    July 2022 edited July 2022
    Thanks very much, I will try to update my video and instructions to incorporate this tip!
    Regarding motion builder, there may be conflicts with the bone rotation conversion process used by the DazToMaya bridge.  Currently, for animations to work, animations are disabled.  I am looking into a complete bone rotation solution for animations.
    Post edited by danielbui78 on July 2022
    July 2022
    The July Update for the Daz to Maya Bridge is now available on Daz Central and Daz Install Manager!  Please refer to the main post for more information about this update.
  • Venomacid88Venomacid88 Posts: 18
    July 2022
    So I installed the July update. I chose the module folder in the specified area; which is also the default area that pops up when installing the bridge in Maya from Daz. I ran Maya and the plugin manager didn't find it. I created module folders in 2022 and 2023 as someone suggested, "Just put in Documents\maya\mayaVersion\modules, or create the folder..."  That didn't work either when restarting Maya and checking the plugin manager. Any ideas?
    July 2022
    Btw, This is how my character looks in Daz after I use the bridge to export to Maya.
    4000 x 3000 - 6M
    Maya modules are not managed by the plugin manager and will not show up there.  Please post a screenshot of your maya window and the script console area and any error messages that may be there.  Thanks.
    Regarding the post-export character issues, please report the following:
    1. Daz Assets with links to daz store when possible
    2. Applied morphs and morph strengths
    3. Morphs selected from Morph Selection Window
    July 2022
    Here's the Screenshot from startup on Maya. The DaztoMaya shelf is blank. The Script console doesn't show Daz having any sort of presents in the startup.
    3839 x 2041 - 504K
    July 2022
    1. Open Daz Studio to blank scene
    2. Click File -> Send To -> Daz to Maya
    3. Click "Install Plugin", you should get a popup showing the path to where the Maya module was installed.  Please take and post screenshot.  It should look like image 1.
    4. Open Explorer window to the path listed in the popup.  Take a screenshot.  It should look like image 2.
    5. Double-click the DazToMaya subfolder.  Take a screenshot.  It should look like image 3.
    6. Open Maya 2022.  Open Script Window.  Start a Python tab.  Type:
    import sys
    print(sys.version_info)
    and press "CTRL+ENTER".  Take a screenshot.  It should look like image 4.
    747 x 656 - 120K
    1191 x 747 - 86K
    1174 x 754 - 84K
    949 x 793 - 57K
    July 2022
    import sys
    Done. The only difference I see is in the 4th image.
    3854 x 2142 - 1M
    1815 x 955 - 111K
    1840 x 955 - 101K
    3842 x 2035 - 328K
    July 2022
    Everything seems to be in the correct spot.  Try adding a custom shelf script:
    1. Open Script Editor and copy and paste the following into a new Python tab:
    import sys
    sys.dont_write_bytecode = True  # don't write PYCs
    import maya.cmds as cmds
    import DazToMaya
    if int(cmds.about(v=True)) > 2020:
        import importlib
        importlib.reload(DazToMaya)
    else:
        reload(DazToMaya)
    DazToMaya.run()
    2. Then click on the Script Editor Menu: File -> Save Script to Shelf...
    3. Type in "Daz Import" and hit Enter
    4. A new custom script should appear in the Shelf
    5. Click the new custom icon and Daz To Maya Bridge dialog should open
    6. In the Script Editor, you should now have output with Python Version, DazToMaya version and Intermediate folder location
    958 x 818 - 69K
    July 2022
    import sys
    import DazToMaya
        import importlib
    else:
        reload(DazToMaya)
    DazToMaya.run()
    Yes, Pasting the script in the python tab worked. Thank you so much!!
    July 2022
    No luck with adding Redshift to be part of the converting materials drop down menu?
    July 2022
    Sorry, Redshift material conversion is not currently supported in the Daz to Maya Bridge.  You may be able to find some scripts to convert Arnold to Redshift online.
  • JamesJames Posts: 1,146
    Daz to Maya menu / module doesn't appear on my MAYA 2023.
    I have install the plugin to modules folder from DAZ Studio.
    Edited:
    Never mind I look at the wrong place.
    Post edited by James on July 2022
  • linoge8888linoge8888 Posts: 101
    August 2022
    I'm confused. I've installed the bridge with DIM and when I click on it in DAZ (script menu), nothing happens/opens up. I reinstalled the bridge twice, in vain. And the bridge tab in Maya magically vanished and is yet to be found. That update basically destroyed everything. I just don't understand.
    August 2022
    The menu options and install steps have changed, so long-time users may get lost.  Please try reading through the first post and watching the video: https://www.daz3d.com/forums/discussion/574846/official-daztomaya-bridge-2022-july-update-what-s-new-and-how-to-use-it/p1. ; Hopefully that will fix your problems.
  • peterpeterpeterpeter Posts: 34
    August 2022
    Thanks so much for your work danielbui78!
    Do you have an ETA for the upcoming update? You said on Github that you were working on adding JCM support, and I honestly can't wait for that to be implemented! smiley
    Thanks.
  • Krys KryngleKrys Kryngle Posts: 313
    August 2022
    Thanks.
    Ditto on that.  I'm still using Laylo's script until the update.  Looking forward to the next release!  :)
  • stepharamburustepharamburu Posts: 33
    August 2022
    Hi Daniel. Please, how I can use this option on DaztoMaya Bridge? I thing I'm using the right option but the mesh looks identical as the Base Mesh Level 0 (without HD Morphs) but with high subdivisions. It's mandatory to bake subdivisions from Daz to export it to Maya? The problem is the huge use of RAM. Thank you so much in advance. Steph
    1075 x 315 - 90K
    434 x 681 - 44K
  • jeronimocollaresjeronimocollares Posts: 135
    April 2023
    In 2024
    # Error: OSError: file C:\Program Files\Autodesk\Maya2024\Python\lib\site-packages\pymel\internal\parsers.py line 801: Cannot find maya documentation. Expected to find it at C:\Program Files\Autodesk\Maya2024\docs\Maya2024\en_US
    updateRendererUI;
    Like...'what?'
  • 2aragog2aragog Posts: 0
    April 2023
    In maya 2024
    # Error: OSError: file C:\Users\2arag\AppData\Roaming\Python\Python310\site-packages\pymel\internal\parsers.py line 801: Cannot find maya documentation. Expected to find it at C:\Program Files\Autodesk\Maya2024\docs\Maya2024\en_US
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
