Wow this thread is kind of old. I was hoping to find a solution to a question I have about the supersuite. I was interested in it due to the fur texture. Yet It does nto seem to load nor render. I would like a bit of help with this please.
They are for 3Delight renders - at that time there was no Iray.
Kerya is right, they aren't for Iray. Whan you say they won't load, are you getting an error message, or do you just not see any fur before you render? If it's the latter situation swit h the render engine to 3Delight; the fur won't show until the image renders.
OK! YA! Was not expecting such a quick response in this old thread. Thank you much Kerya and riftwitch.And you are correct that was the trouble. When applying the shaders the surface would turn blank plasticy. SO I was thinking something else was wrong. I have a lot to learn in DS. Switching render engines the plastic looking areas did render propper..
Thank you also RCTSpanky for the IRay fix. I thought I had these already some where... Dusting of DS from a long time away from it.
Awesome! That did the job perfectly.
I only JUST learned of the surface selection tool yesterday, but didn't think to apply it to this!
I hope the promised video (usage of Transfer utility) was not also forgotten :(
ill get to it this week
Any news, please?
You are talking about the fur shaders? https://www.daz3d.com/supersuit-fantasy-pack
But you can add any Iray Shader to the surfaces, like this ones: https://www.daz3d.com/leather-and-fur-iray-shaders
We try to be helpful when we can. :)
