Can you change the color of "camera lines"?
I was adjusting a camera's Depth of field today, and realized it would be easier to see what i was doing if I could change the color of the...lines/planes/thingees...from the camera...the frame box, the DOF planes,..those things...
Is there a way?
Select the Camera in the Scene pane (any new camera but NOT Perspective View) In the Parameters pane, select 'Camera' and make sure that Depth of Field is set to 'On'
Switch to Perspective View to see the results on the Camera. Under 'Display' in the Parameters pane, there are 3 colours that you can change Fov Colour, DOF Pane Colour and DOF Overlay Colour. You will see them in the Perspective view with the Camera selected.
Perfect! Clear and concise! If only all answers were such :D
Thank you, much appreciated.
