Weird transparency with shaders
UthgardUthgard Posts: 883
I apologize if this issue has already been adressed, but I haven't been able to find anything on the forums and it's quite annoying:
When applying shaders to surfaces, sometimes I get "grids" or splotches of transparency. It has happened with the Dark Corrosion Shaders, the Historical Masonry Shaders and the Historical Flooring Shaders, but I am guessing it could happen with other packs, seeing this track record. I haven't got a clue about what could be causing this issue, and any help would be greatly appreciated.
The image shows an attempt to mod Faveral's Medieval Blacksmith and a primitive plane.
  • Richard HaseltineRichard Haseltine Posts: 109,533
    That looks like two coincident layers of geometry. Try moving the plane up or down a bit.
  • ValandarValandar Posts: 1,418
    It could also be displacement affecting the geometry. If I may ask, can we see your render settings? Sometimes too low settings cause displacement to do this.
  • UthgardUthgard Posts: 883
    Thanks for the suggestion, but the trouble remains with just a primitive plane (though not as exxagerated without the Skies of Economy lights, it may be related), no matter how much I move it around. Regarding my settings, here is a screenshot of what I use in 1920*1080 images. Thanks to both of you.
    1920 x 1080 - 303K
    Ah, if you are using an environment light - as I think you would be in Skies of Economy - you might try converting the plane to SubD.
    edited January 2015
    About that... Here's an example of a subdivided plane with no illumination with the Historical Masonry Shaders applied. I really liked the promos, but I am afraid I will be returning this one if I don't figure something out soon.
    1920 x 1080 - 687K
    Post edited by Uthgard on
