Carrara EnviroKit Woodlands
SimonJM
This shows up in in DIM as Part 1 in Updates and Part 2 as a new install. Neither actually install:
Installing product : Carrara EnvironKit - Woodlands - Part 1
Product installation failed : Carrara EnvironKit - Woodlands - Part 1
Install Queue finished in 0 min 0.6 sec.
Current Content Install Path:
Location = C:/3D/Carrara
Disk Total: 223.5 GB (240054693888)
Disk Avail: 84.1 GB (90356461568)
Installing product : Carrara EnvironKit - Woodlands - Part 2
Product installation failed : Carrara EnvironKit - Woodlands - Part 2
Install Queue finished in 0 min 0.8 sec.
This product was updated as the size of the original file was giving people problems with a manual install, so it was split into 2 installers.
However there is a slight problem with this. See this thread in the Carrara forum http://www.daz3d.com/forums/discussion/50488/
Ah ok, so it's a non-update update, where the content remains the same, just the delivery is different (two files instead of the original one).
Couldn't have put it better myself.
Yeah ran into same problem would not install just download manually and move files to respective folders. Works fine.
The recent update fixes the issue, thanks.
