Animate 2
I went to put my Animate 2 on my Parameters tool and it has disappeared. I went to the serial numbers and it has also disappeared.Does anyone know what is happening? Cheers
Disappeared from where? And what do you mean by putting it on the Parameters tool?
When undocking the parameters pane I add other tools such as Surface, Rendering, etc. Animate 2 is no longer available in my panes options. However, it is working on my other computer. Perhaps it is because I am using a beta program! Cheers
OK, so it's panes not tools. Have you checked Help>About Installed Plug-ins? If it is serialised it should not have a greyed out placeholder for the serial number (though if it isn't serialised you should still have AniMate Lite). It's most likely to be a version mis-match between DS and the plug-in.
