Animate 2
I went to put my Animate 2 on my Parameters tool and it has disappeared. I went to the serial numbers and it has also disappeared.Does anyone know what is happening? Cheers
  • Richard HaseltineRichard Haseltine Posts: 111,816
    Disappeared from where? And what do you mean by putting it on the Parameters tool?
  • When undocking the parameters pane I add other tools such as Surface, Rendering, etc. Animate 2 is no longer available in my panes options. However, it is working on my other computer. Perhaps it is because I am using a beta program! Cheers
    OK, so it's panes not tools. Have you checked Help>About Installed Plug-ins? If it is serialised it should not have a greyed out placeholder for the serial number (though if it isn't serialised you should still have AniMate Lite). It's most likely to be a version mis-match between DS and the plug-in.
