looking for postal worker outfit
I am looking for a postal worker outfit for either G8F or G8M does anyone know where to find a good one?
  • ecks201ecks201 Posts: 485
    edited April 2022
    What nationality and what era?
    Post edited by ecks201 on
  • FirstBastionFirstBastion Posts: 8,050
    I don't think there is a specific Postal Service uniform in the store.  Try using the search term "uniform"  and see if something atleast comes close
    This outfit could work for some specific time period. But its not a modern option
    https://www.daz3d.com/dforce-lighthouse-keeper-for-genesis-8-males
  • techd84techd84 Posts: 5
    I was thinking modern look and usa from the usps"united states postal service". Doing a search for "unifom" gets shcool, sports, or law/ militry.
  • AscaniaAscania Posts: 1,855
    So a generic light blue shirt and somewhat darker trousers or shorts?
    that would get close enough if there was a messenger bag as well
  • 3Ddreamer3Ddreamer Posts: 1,347
    edited April 2022
    Would either of these work? I searched 'Bag' in the store - far from perfect search...
    https://www.daz3d.com/dforce-medieval-peasant-for-genesis-8-males
    https://www.daz3d.com/dforce-despair-for-genesis-8-females
    I'm not sure what a USA/UPS Postal Worker wears, without a photo of what you have in mind.
    Post edited by 3Ddreamer on
  • CybersoxCybersox Posts: 9,440
    edited April 2022
    How about these - Toyens Sheriff and Female Police Officer uniforms recolored with all the police specific badges and patches hidden, a different hat and the bag from the G3F Upscale Shopper outfit.  I just did both of these in about ten minutes by dropping the original image maps from the base surface and replacing it with the needed colors, and Toyen thankfully does all their badges on seperate layers that can be turned off by dialing down the opacity..  The cap (from the scifi policer officer) also had a patch reading POLICE that could have been redone to USPS, but that seemed like overkill for a proof of concept
    769 x 1000 - 626K
    Post edited by Cybersox on
  • McGyverMcGyver Posts: 7,085
    edited April 2022
    You could retexture this... but it's for M4, so probably not worth the trouble refitting it...  https://www.renderosity.com/rr/mod/bcs/desert-rats/121969/
    It even has a pith helmet like the postal workers wear in the summer...
    It looks too military and you'd have to omit all the extra stuff like ammo packs and the harness...
    If you just want the helmet...
    There is a free pith helmet here if you want one... https://sharecg.com/v/49470/gallery/11/Poser/Safari-Helmet-for-M4
    Thats also for M4, but hats and helmets are easier to refit.
    Post edited by McGyver on
    The lighter set that Cybersox posted is very near. Is it posable to put the less metle belt from the dark ouffit on the lighter one. The bag is the only thing that look off to me it looks more like a large purse. are there any cross body single strap messenger bag anywhere?
    As for the belt, no, but you can just to hide the metal and it'll look like the other.  I didn't do that because it left the key ring.  As for the bag... as noted, I did all that in about 10 minutes, so I just grabbed something I already had loaded for another project.  It also depends on what you mean by cross body, but there's a ton of bags out there that can be adapted.  It happens that my ex's mom was a mail carrier and she always wore the bag on one side as doing otherwise was considered too dangerous... with the bag wrapped around your neck and torso it's far too easy for someone to grab it and pull you out of the truck, or to the ground, to get hung up getting in and out your vehicle, and, most importantly, you're unable to use against a dog in case of attack as per the offical SUPS policy.    The bag I mainly see used these days looks more like a soft refridgeratated cooler bag when open, and a school bag when closed, but they're very elaborately marked.  Leather bags are still used in bad weather conditions as no amount of weather proofing will keep paper dry niside wet cloth.
    I never though about the danger part of waring it cross body.
