• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz to Blender plugin bug workaround for MacOS & Rendering in Blender using Cycles and M1 GPU/Metal
extract0rextract0r Posts: 0
April 2022 in Blender Discussion
Hi all, I got a workaround for the Daz to Blender plugin if it doesn't work for some of you and a tutorial on how to render in Blender using the Cycles engine and M1 GPU/Metal
I am using it on MacBook Pro M1, MacOS 12.2 Monterey, Blender 3.1, Daz Studio 4.20 Pro, so I don't know if the same workaround works on other platforms. I think it might be helpful for people who want to render via Cycles and utilize the M1 GPU (which is available in Blender 3.1).
DAZStudio:
Step 1) Download Daz Studio and Daz to Blender plugin via DAZ3DIM (you must purchase the Daz to Blender plugin in the Daz Store for $0)
Blender:
Step 1) Download Blender 3.1 and Blender 2.93 (or another version that is 2.80 or higher, 2.93 works for me and it is the first version which supports arm64 - the M1 Chip natively)
Step 2) Download Daz to Blender plugin from GitHub, unpack the .zip
Step 3) In Blender go to Edit -> Preferences -> Addons -> Install, then choose DTB.zip which should be located in ../DazToBlender_2.4.0/Blender/DTB.zip (do this for both Blender versions)
Import to Blender from DAZStudio:
Step 1) If you cannot see the scripts menu in DAZStudio, go to Window -> Panes (Tabs) -> Script IDE
Step 2) In the Script IDE choose File -> Open Script -> Manually choose the Daz to Blender plugin, which should be located by default in ../Applications/DAZ\ 3D/DAZStudio4\ 64-bit/scripts/support/DAZ/Daz\ to\ Blender.dsa -> click Execute
Step 3) Choose the settings you want
Step 4) In Blender 2.93 choose the little arrow below Options menu on the right side of the screen -> Daz to Blender -> Import New Genesis Figure
Step 5) It should import the character without any Python-related errors, after that save the blender project
Step 6) Open the Blender project in Blender 3.1
Rendering using Cycles and M1 GPU/Metal in Blender 3.1:
Step 1)Choose Edit -> Preferences -> System -> Cycles Render Devices -> Metal -> Apple M1 GPU (the Apple M1 option means CPU rendering, there is also the MetalRT option, which means that you will enable Ray Tracing, you must choose M1 GPU if you want to use MetalRT, correct me if I am wrong)
Step 2)Choose Render Properties tab on the right side of the screen -> Render Engine: Cycles, Feature Set:Supported, Device:GPU Compute (for MetalRT you should choose the Experimental Feature Set, correct me if I am wrong)
Step 3)Choose Render -> Render Image (F12 keyboard shortcut)
Step 4)Done
  • RL_MediaRL_Media Posts: 339
    April 2022
    I am sure there are mac guys thanking you for this.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
