Zev0 Promo Character/Hair?
Does anyone recognize the character shape, textures, and/or hair used by Zev0 in the main promo pictures for Brightness Manager?
I tried looking for the hair here and I had no luck finding it. I tried comparing the textures of the promo model to Zev0's other characters and Mia HD texture looks similar but the freckles and eyebrows are off.
  • rosselianirosseliani Posts: 516
    And the character looks like a ZevO's character, Liloo, Lily, Molly... Or a mix of them... Really beautiful young characters.
    The only problem with ZevO's characters is the hair distortion caused on a lot of hair assets  around te ears area.
    This dirtortion problem occurs also with some characters that use  Growing_Up young morphs.
    dForce hair assets sometimes partially help to fix the unwanted deformation, but as I say, partially...
    Wish you a Happy Easter!
    got any examples of the hairs that cause problems? Usually you can dril down into the hidden parameters for hairs and find the areas around the ears and turn off those morphs to eliminate the problem.
    to the OP, only Zevo would now the actual answer and they have commercial threads in the commercial forum, so you could just PM them and ask.
    As I said, the hair distortion problems occur with some characters that use  Growing_Up young morphs.
    And ZevO's characters use GU young morphs.
    Here is one example of Liloo HD with Paloma Hair (from another store)
    Even tweaking the "ears" hidden parameter I can't get a nice result.  (I choosed the "worse" example to illustrate what I said).
    I'm a great fan of ZevO's products.
    I remember ZevO's advice for hair causing problems: Load the hair separately from the character, scale the hair to manually fit the head and parent the hair to the head without autofitting. It works quite good.
    Have a nice day!
    1097 x 620 - 69K
