Can’t get Jepe shape to work.
So I just got https://www.daz3d.com/jepe-s-enzo-m4 to use as a genesis 2 figure. I have the required M4 for G2M product. I have successfully applied the textures to the genesis 2 base figure but I can;t work out how to get Enzo's shape. Help!
  • GordigGordig Posts: 10,811
    M4 shapes require conversion to use on Genesis figures. You'll need GenX plus the G2 add on.
  • GhostDogGhostDog Posts: 156
    Thanks Gordig.
    Urgggh! Is it just me or does the product page make it seem this should work as a genesis 2 figure if you have the listed add-on? I feel a bit jipped.
    okay, is the way you list the best way if I am ultimately heading for genesis 3 or 8? Or is there a different product to convert to them?
    Oh, I thought you were talking about Cayman Studios' legacy UV products. Yes, Enzo's description does make it seem like you should be able to dial that shape into G2 if you have the required product, but I don't own M4 to G2 or Enzo, so I can't really check it out for myself.
    The required utility page https://www.daz3d.com/michael-4-for-genesis-2-male talks about using shapes and not just textures. I just can"t see how I"l supposed to use the supplied M4 injection morphs from Enzo.
    That page does include this text:
    **Genesis 2 Male can only use presets saved in the DUF format, so presets saved in other formats must be converted to DUF and saved before applying to Genesis 2.
    Does Enzo include a DUF preset? If not, have you saved one yourself?
    I think you have something there! How do I do that?
    I think I found the answer for anyone else looking https://www.daz3d.com/forums/discussion/220726/how-to-convert-to-duf-format
