There are many black dotted line in my hair material
They can be seen somtimes,when I render a video.
How can I remove them?
I think this problem is related to BaseHairMaterial file,but I can not fix it. Thanks!
Do you see those on the character? Those pop up because I set the material to use dithered alpha. Try adjusting the transparency until it looks correct on the character.
https://davidvodhanel.com/daz-to-unreal-adjusting-hair-transparency/
Thank you. I will try when it appears again.
