• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz to blender bridge not showing up in Daz
Spike-n-ArtSpike-n-Art Posts: 3
February 2022 in Blender Discussion
I have just installed the Daz to blender bridge and there is no longer a scripts option on the menu bar.
  • RL_MediaRL_Media Posts: 339
    February 2022
    Sometimes going to window>workspace>"update and merge menus" will bring back missing script stuff.
  • butaixianranbutaixianran Posts: 161
    February 2022 edited February 2022
    Make sure you following the tutorial at github:
    https://github.com/butaixianran/DazToBlender
    Also, you need the updated one for blender 3.0:
    More information check here:
    https://www.daz3d.com/forums/discussion/546316/daz-bridges-update/
    Post edited by butaixianran on February 2022
  • paulben65_e91e87f10bpaulben65_e91e87f10b Posts: 1
    March 2022
    I have this issue and it is driving me crazy. The script menu does not appear. I have used Download manager, Daz central and also tried the Github manual install. None of these work. No script menu. The anoying thing is that I had it working fine but needed to re-install windows. so I know that it should work for me. It has installed fine on Blender. When I start Daz Studio for a split second the menu bar flashes with the script menu there then it disappears. Any help would be most appreciated.
  • money.moneta9money.moneta9 Posts: 0
    March 2022
    I also have this issue. However, the scripts button never appeared for me at all. I've tried uninstalling/reinstalling the plugin, and uninstalling/reinstalling Daz Studio, but with no effect. I tried checking the daz to blender github page to manually install the plugin but that didn't help either. One thing I've noticed is that the install location for my daz studio (and thus the location of my plugins) is different than the default installation for daz studio listed on the github page. My installation is located in: "C:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4", while the github indicates that the default path is: "C:\Program Files\DAZ 3D\DAZStudio4." Could this have anything to do with it?
  • pinterpinter Posts: 0
    April 2022
    Same here, except I'm on macOS 10.15.
    I *was* able to install and use the Blender bridge (once) by manually running the Daz to Blender_Install.dsa script immediately after a DIM re-install of the package, but that fix isn't persistent; today the 'Scripts' menu option has again disappeared from DS.
    Window->Workspace->Update and Merge Menus is ineffective.
    Guys, we really shouldn't have to grease it this hard.
  • Richard HaseltineRichard Haseltine Posts: 111,444
    April 2022
    The issue with saving layouts is cross-platform. The method given here My workspace resets every time I reopen Daz. - Daz 3D Forums  should work on Macs, replacing the Appdata folder with Application Support in your library folder.
    April 2022
    Qapla'!
    Per your link, I 'touch'ed those files, re-installed the Blender bridge and verified the newly-created actions.dsx and friends had content.
    But, still no Scripts menu option until I switched the default Window->Workspace->Select Layout to 'Full Service [Beta]' and back to 'City Limits'.
    It seems happy now. Thank you for all your prolific posts and hard work!
  • therealcyberpunk88therealcyberpunk88 Posts: 0
    April 2022
    I was literally about to give up NOTHING seemed to work and that "scripts" menu NEVER showed up... deeply frustrated I tried sth extremly weird BUT IT WORKED!!!
    So here is what you do, you install the bridge, then from that github link inside the downloaded folder you find "Use this to Install Daz Side" Folder the file in there is supposed to be placed inside your app-data folder so it loads once you open Daz studio (which never worked for me)
    Now all you have to do WHILE HAVING DAZ STUDIO OPEN... simply drag/drop that file right into the viewport and boooom there you go the scripts menue (including the bridge to blender) will magically appear!
  • ronniejnoronniejno Posts: 0
    May 2022
    Yes, this helps! I had to drag the "Daz to Blender.dsa" file into the viewport, then DAZ started the exporting process.
    I'm on a Mac btw and no method mentioned in this thread worked other than therealcyberpunk88's way.
    So now I have to store these dsa files and do the same every time. I really hope someone can have a peek into this bc this is super annoying.
    Peace out!
  • g2015g2015 Posts: 0
    May 2022
    This worked for me too. Thank you.
    To add a bit more detail for mac owners, the app-data folder is Library/Application Support/Daz 3D/
    Ive re-opened Daz once and found the script menu with blender in it but Im not confident itll always be there so I expect to drag that file in again ocassionally.
    The Blender side has a few quirks also.
    This video helped a lot ->
  • njsnjs Posts: 71
    June 2022 edited June 2022
    It has happened to me too. I tried the GitHub, that didn't work. I tried Uninstalling Daz to Blender Bridge and Re-installing it, that didn't work either.
    Any solutions?
    440 x 142 - 61K
    Post edited by njs on June 2022
  • danielbui78danielbui78 Posts: 333
    Any solutions?
    Daz To Blender has been updated and is now accessed from the File->Send To menu.
    You can find more information, instructions and tutorials to install and use the new bridge in the following places:
    • the FAQ page,
    • the main Github page,
    • the Github Release download page,
    • or watch the installation video on the release thread:
    • https://www.daz3d.com/forums/discussion/572806/official-daztoblender-bridge-2022-what-s-new-and-how-to-use-it
    Post edited by danielbui78 on June 2022
  • BubblyBoopBubblyBoop Posts: 3
    danielbui78 said:
    Any solutions?
    • the FAQ page,
    I have spent days trying to figure this out. You are amazing!!!
    Post edited by Richard Haseltine on June 2022
  • pupetdogpupetdog Posts: 7
    June 2022
    I had this happen to me twice since Daz Studio released 4.20. I was able to resolve it by totally uninstalling both via Daz Centeral. I then installed a earlier release such as 4.15. Then I used Daz Centeral to first, re-install Daz to Blender bridge, then I was prompted to install Daz 4.20. But at that point, 4.15 displayed the script menue at launch.
  • whdixiewhdixie Posts: 0
    July 2022
    You can now access DazToBlender from the File -> Send To -> DazToBlender, similar to Unity and Unreal Bridges.
  • gsecretgarden7gsecretgarden7 Posts: 0
    September 2022
    Yes!! This worked!!! Thanks a lot
  • sugarthemissugarthemis Posts: 0
    April 2023
    I want to help because i had the same issue
    NOT SHOWING in :script -> ok it is ot any more here but ...
    NOT SHOWING EITHER in SEND TO
    so for those in my case :
    when i installed the bridge via the DAZ central or EVEN MANGER it doesn't show up
    WHY ?
    because it has installed the dll file (dzblenderbridge.dll) in another folder than the daz studio file which is in C:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4
    SO here is what i have done : i copy paste the dll file INTO the path above C:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4>>>>> PLUGINS
    FIRST STEP RESOLVED : the send to blender appear in daz studio > fILE > send to
    i don't know if the entire process will worked but ... if my answer can help resolving at least this first step .... then i am happy .....
    April 2023
    ok now you have to open BLENDR to see which verison you have. For me it is blender 3.1.2
    CLOSE IT
    OPEN DAZ and choose a figure
    FILE > SEND TO > daz to blender
    In the box appeard you have to select your blender version (3.1 for me) and CLIC on INSTALL PLOUGIN
    THEN go back to blender and follow thie stutoral
    he will explain you where is the plugin and what to do if it doesn't appear yet (EDIT > preferences > add on > search DAZ > enable the plugin)
    I HOPE IT HELPED
    didn't tested the full process yet. I am going little step by little step....
  • PeakCakeEnjoyerPeakCakeEnjoyer Posts: 27
    June 2023
    UPDATE YOUR DOCUMENTATION.
  • zvzulndrzvzulndr Posts: 6
    July 2023
    WHY ?
    Your resolution worked. Thank you. Also, if you are using the new Blender 3.6, when you download the bridge it only includes 3.2. and 3.5 scripts even though on the DAZ web page it says it supports 3.6. What I had to do was go to the Blender AppData, C:\Users\<UserName>\AppData\Roaming\Blender Foundation\Blender and copy the directory 3.5 to a new directory 3.6. Then Daz will display the 3.6 option, and Blender 3.6 will find the import scripts.
  • saltire2k_986e5095desaltire2k_986e5095de Posts: 1
    February 2025
    Thanks, this worked for me.
  • rykcaverykcave Posts: 2
    June 11
    Recently Installed Daz 6 alongside my Daz 4.24 and while my Daz to Blender bridge works there,
    Daz to Blender does not show up in Daz 6, even tried to reinstal it thru DIM, still it doesn't show in Daz 6
    p.s.
    We should probably have an update for  Daz to Blender bridge .... pretty please ;)
  • ShannonHowellShannonHowell Posts: 10
    July 20
    Yeah kinda frustrating when Daz updates the software and the Daz to Blender doesn't work.  I installed the bridge by using the DIM but it still doesn't show up in Daz Studio 6.   Is there a way to fix this and get it to work or do I just need to uninstall Daz Studio 6 and go back to an early version of Daz Studio?
  • crosswindcrosswind Posts: 10,276
    July 21
    No, there's no way to make it work in DS6 on user's side... you have to wait until Daz releases the updated DTB plugin for DS6 (...if Daz has a plan for updating it ~)
    Instead, you can use Diffeomorphic.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
