Importing OBJ files
mikael-aronssonmikael-aronsson Posts: 599
Hi!
For some reason Carrara does not import any texture maps when I import an .obj file (exported from DS),
I can add the texture map after the import and all works fine, now, I tried to copy the texture file to a different directory and updated the mtl file with the correct path and all worked fine.
The only difference is that the new directory path do not contain any spaces, please do not say that the Carrara obj importer don't handle spaces in the texture path ? it is 2015 now, this problem do not exist any more please!!!
  • JoeMamma2000JoeMamma2000 Posts: 2,615
    Sorry dude. I just tried with an obj file with and without spaces in its name, and no materials imported when there's a space, even in the name. But materials when there's no space.
    Yeah, this is 2015. But this is Carrara, too... :)
    I've got a whole list of head scratchers. :)
  • mikael-aronssonmikael-aronsson Posts: 599
    Ok, I just bought a new computer so I might as well delete it all and reinstall all content in a directory without spaces then, otherwise I will loose all my hair soon.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,560
    Check your export options in DAZ studio as I do them with textures all the time.
    Use original textures should work
    also write material file
    it does often miss the bump or displacement files though depending on what is exported.
    If you have C8.5 you can save a duf scene and import that too
    if it is a Poser file pp2 or pz2 you can load it directly from your runtime.
    Ah, you mean the "Collect maps" option that create a subdirectory with all map's ?
    Did not see that one, that should help, thanks.
    You should not need to, use original maps should work as long as you have a mtl file telling the obj where to find them.
    DAZ studio itself will not load the maps reimporting the obj by the way but Carrara will as does iClone 3dxchange and Octane renderer among other things I use, only DAZ and Poser sometimes give me issues, both those need the maps in the same directory instead of reading the mtl file to find them.
    Also if carrara CANNOT find the maps
    it WILL ask to browse to them if you have a mtl file
    AND once you have located the first one it will load the others.
    No, Carrara did not ask for them, it just ignored them, when I modified the mtl file to a path without spaces and moved the texture map there it worked fine.
    Not sure why it did not ask for them though.
  • Design AcrobatDesign Acrobat Posts: 459
    edited January 2015
    Just use convert maps for Bryce and it should import fine into Carrara. It should make an obj file and a folder with your textures. The only thing you should have to do is adjust the shininess or whatever as they get blown out in Carrara.
    In fact, I keep Carrara as the default program for opening OBJ files (file association) so all I have to do is double click the icon (usually on desktop) and it auto loads with obj and the texture files. No muss, no fuss and no wearing of the hernia truss...
    edit the render is a quickie in Carrara 8 Pro
    481 x 550 - 63K
    Post edited by Design Acrobat on
    I rarely do figures as see no reason to I open them or import them as duf or cr2 rigged.
    I just tried it, you were right my settings a figure did load untextured .
    I definitely have gotten textured files in though maybe I used the Bryce settings too am now very puzzled it WAS before DS4.7 maybe something has changed???
    When I attempted this, I made sure I had both an .obj and a .mtl file, and changed the names of both files to add a space. And clearly, with the space in the name of both files, Carrara, failed to import the .mtl file. Without the space it worked fine.
    So unless I missed something, it's choking on spaces in path references.
    I clicked view and see you may be right JM2K, I think it s a DS4.7 obj export change though, a few odd things have occurred for me in this build
  • DiomedeDiomede Posts: 15,410
    I also think something is up with the 4.7 export function. I've had screwy results with duf files saved out of Studio that I have tried to open in carrara. I can load the files directly in carrara no problem, so I don't think it is just carrara having trouble with the folder names.
    For info, my results had nothing to do with DS. The .obj was generated in Hex I believe.
  • Bunyip02Bunyip02 Posts: 9,292
    Hello all
    A couple of quick screendumps for the obj files.
    I am using DAZ3D 4.6
    Is the 4.7 Obj export parameters the same as 4.6 ?
    Sometimes I forget to tick the "Collect Maps" option which results in the maps being left behind.
    Same issue ?
    1363 x 773 - 344K
    1361 x 768 - 365K
