The Watchmaker and the Automaton
https://www.daz3d.com/the-watchmaker-and-the-automaton
When I select the automaton, all that opens is the head gears. Not even the head, just the gears. What am I doing wrong?
  • Richard HaseltineRichard Haseltine Posts: 111,598
    Maybe you need to have the base figure (Genesis 8 or 8.1 Female I assume) loaded and selected?
  • watchdog79watchdog79 Posts: 1,026
    Correct. It is an outfit, not a figure.
    thanks
  • First time I have seen that set. It's astonishing. The level of detail, and modelling precision. Most impressed. The watchmaker's lathe.. instantly recognisable and it should work if printed.
