[Released] Turbo Loader for Genesis 3 [Commercial]
RiverSoft ArtRiverSoft Art Posts: 6,975
Do you have a large content library? Have you started to dread loading a Genesis 3 figure because it can take so long? Then the Turbo Loader for Genesis 3 is for you! Turbo Loader turbocharges Daz Studio for users with large content libraries. By disabling unneeded morphs for your Genesis 3 figures, see dramatic speed increases in loading scenes and figures, and even clearing scenes.
The first time that Daz Studio loads a Genesis 3 Female or Genesis 3 Male in a scene, Daz Studio searches your content directories for all the morphs used by that figure and creates properties to control them. With a large content library with lots of morphs, this operation can take a long time. However, for most scenes, you don't need all of those morphs. The Turbo Loader scripts detect ALL morphs in your system for Genesis 3 Female or Male and organize them by product. Turbo Loader will work with morphs installed manually, by Daz Install Manager, or even by Daz Connect!
Disable all the morphs for a figure type (except some important products such as Genesis 3 Starter Essentials). Then, quickly enable select morphs for the scene you want to create. You will be amazed at how much more responsive Daz Studio is!
  • Turbocharge the loading of figures* and scenes.
  • Finds morphs, properties, and aliases wherever they are located, even in multiple locations such as products installed with Daz Connect.
  • Organizes morphs by product, allowing you to easily enable and disable morphs to suit your current needs.
  • Create configurations to quickly and easily enable or disable sets of morphs before loading figures.
Products installed manually or with products like Content Wizard do not have morphs recognized by the Daz Studio database. They will be organized as unknown products with a name from their parent directory.
*This is very dependent on the number of morphs you have for a figure generation. In tests, we have seen speed increases from 6-17x faster!
Tutorial (v1.1)
Tutorial (v1.0)
Note
If you buy the product when it is available, I would love if you post to this thread your before and after loading times (and number of morphs).  I would like to compile a larger table of times to let other users know what speed increases they can reasonably expect.  Just record the time it takes to load your G3 character with all morphs enabled, disable everything except the core set of morphs, and then record the time it takes load a the base G3F/G3M character into a new scene.
Post edited by RiverSoft Art on
  • jedijuddjedijudd Posts: 606
    Have had a chance to try your G8 version yet, but I look forward to this one also
  • RiverSoft ArtRiverSoft Art Posts: 6,975
    Thanks!  I think you will like it!
  • GatorGator Posts: 1,320
    Awesome! I read the thread above and immediately ran to the store looking for an earlier Genesis 3 version. Great to see Genesis 3 isn't forgotten yet. Do you have an ETA?
    It should be soonsmiley
    And it is released!
    Turbo Loader v1.1 should appear this week (probably today).  You might want to check out the updated video:
    Submitted update today:
    • Updated RSTurboLoaderConstants.dsa file for Turbo Loader for Genesis 9 support
    • Modified getting selected assets in Turbo Loader Scene Configuration to ask which you want to use, if both Smart Content and Content Library panes are visible and have selected assets
    • Changed GetFilesFromDir function so that the function ignores symbolic links
