I don't like this modeling method
DiomedeDiomede Posts: 15,410
edited March 2022 in Carrara Discussion
Free - so I should not complain
I downloaded a free Star Trek Galileo Shuttle from ShareCG.  This is the episode where Spock commands a shuttle expedition to a planet of giant stone age humanoids.
The person modeled all of the textures into the mesh, including the letter script for the name of the shuttle, but the letters read backwards.
https://www.sharecg.com/v/78904/related/21/DAZ-Studio/Star-Trek-V-Galileo-Shuttlecraft-for-DAZ-4.7
Post edited by Diomede on
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,640
    import it flipped or flip it and the normals in the vertex room
    yeah, mesh letters can be overkill but if a separate mesh not hard to remove
  • ProPoseProPose Posts: 547
    I could'nt  even get the model into Carrara from the prop folder in duf format,  I get a nil pointer error.  the obj from the runtime folder comes in properly,  I used these import options
    520 x 558 - 42K
    1920 x 1049 - 235K
  • Bunyip02Bunyip02 Posts: 9,292
    edited March 2022
    I used that Carrara plugin that they have to give away for free, DAZ Studio, adjusted the Scale for the X Scale to -100%.
    Then I exported that item as an obj, and imported it into Carrara.
    1901 x 1003 - 201K
    2265 x 1038 - 437K
    Post edited by Bunyip02 on
  • DiomedeDiomede Posts: 15,410
    Excellent, Bunyip.  I will do that.
    I am curious.  In which rendering program is the mesh reversed like this?
    Hello Diomede, the text is reversed in DAZ Studio when you scale X Scale to -100%
    Also use the scaling to -100% to convert left hand drive vehicles to right hand drive vehicles !
  • SileneUKSileneUK Posts: 1,977
    edited March 2022
    About the cars. It does change it the way you said, but if the dash is important... it will be backwards. And if you have a number plate/licence plate, you need to photoshop or whatever to put it in reverse otherwise the lettering comes out backwards. Same if there is writing on the hood/bonnet.  But it has been very useful for me to do this. Great hack. Thanks for the reminder!!  I did this on https://www.daz3d.com/car-ranger
    yes Silene
    Post edited by SileneUK on
  • UnifiedBrainUnifiedBrain Posts: 3,588
    A very nice tip Bunyip, and well illustrated - thanks!  I admire your ability to manipulate stuff in DS.
    I am slowly getting familiar again with DS (for the plugin value), after years of going cold turkey into Carrara.  A lot to relearn.
    edited March 2022
    Thanks, @ProPose.  I missed your solution at first.  I had forgotten that Poser-format content includes the OBJs in a geometry folder.  I wonder why the result is getting inverted in the X axis if the OBJ is not.  Hmmm.
    Saves some steps. yes
    edited March 2022
    Bringing the item in as the Poser obj loses the colour info, you then need to reapply the colours in Carrara.
    As to why it's inverting the model in the DUF file is a mystery !!!
    Hello UB, I started out with DAZ Studio before I saw the light and emigrated to Carrara. I did keep my skills with DS as I thought it might be useful. Still using version 4.10 though.....
  • StezzaStezza Posts: 8,935
    edited April 2022
    tried this to pass a bit of time..
    I extracted the OBJ file from the zip file, imported into Carrara and textured using Carrara's plastic shaders
    640 x 480 - 166K
    Post edited by Stezza on
  • rk66rk66 Posts: 450
    Here a similar free shuttle (car version) by spacebones > https://sharecg.com/v/63188/gallery/5/3D-Model/Multi-Purpose-Shuttle-MPS2A-Beaver-Carrara
