Missing Files after installation: Cyclorama-Portrait Paper Backdrops
I use DIM for all my installs. Several products are missing files when I attempt to load them. Most recently, https://www.daz3d.com/cyclorama-portrait-paper-backdrops opens with errors (listed at the bottom).
What is causing this and how do I fix it? Why does this occur with Daz Store items installed using DIM?
Thank you for any assistance!
I receive the following errors:
Missing Files:
/data/DAZ 3D/MPCyc/Multiplanne Cyclorama/blMPCyc_1163.dsf
/data/DAZ 3D/MPCyc/Multiplanne Cyclorama/UV Sets/DAZ 3D/Base/default.dsf
I think there is a dependency that is no longer listed, probably because it isn't in store any more.
it exists
https://www.daz3d.com/multiplane-cyclorama
Then it just look like they have lost a dependency.
I'll flag the lack of required product details up, thank you.
I got most of the addons also
Woodland Realm Playset One | Daz 3D
Woodland Realm Playset Two | Daz 3D
Serengeti | Daz 3D
and many more, I actually use these a lot outside windows LaurieS has awesome textures for them
gepetersiii do you have all the starter essentials installed for the earlier figures?
there should be a Surfer Guy scene with the Multiplane Cyclorama
this is likely why it is not listed as a requirement because most people download all the starter essentials
Yea, I forgot about those I bought the Multiplane Cyclorama back in 2007 or so with the Woodlands.
Just verified, yes, I have all the Surfer Guy content installed.
you might need to load the Multiplane Cylorama first then and apply the paper shader to it, it's obviously not finding it on it's own, this could depend on how you install stuff, using things like Connect or DAZ central can do some stange stuff.
