Baseball Animations for Gen 8.1 does not work with Lincoln figure
in The Commons
OK, I bought Baseball Animations for Genesis 8. I want to use it to create stills of a baseball player at bat. It works great with the Genesis Male and Kayden 8.1. Just click on the presets and you are in business. However, the same is not true for the Basic Child/Lincoln. The poses are all wrong. Why does Baseball Animations not work with the Basic Child/Lincoln product? If it indeed, does not work, then is there a 7-year-old character that it will work with?
Hmm, I don't know why it wouldn't work, I don't have Lincoln to test it, but what should work is load in Kayden, dial him out and dial in Lincoln. Then you're using a character you already know works with the morph you want to use. It's not the ideal answer or use, but it is a workaround if you really wanted to use Lincoln in your shot.
Maybe the animation presets are using a heirarchical preset to load the animations & there wasn't such a preset done for Lincoln? What benniewoodell says should work for you though.
