Looking for short dforce hair with full movement
I am a big fan of dforce hair and I am constantly looking for the best ones that have full movement (turn the figure upside down, does all the hair move?) since I need the hair to go into extreme poses most of the times. Other than the Linday, Phil W and Biscuits hair, any others with full movement that I might have missed, especially short styles.
  • GordigGordig Posts: 10,785
    How much have you messed around with the surface settings? You can generally get more movement out of hairs than the creators might have intended by lowering the global and local shape constraint stiffness.
  • FSMCDesignsFSMCDesigns Posts: 12,855
    I have played with dynamic strength, even tried to change the weight mapping, just gets tedious when I just want to load and simulate. I have a commision and the client is set on short hair and I can't seem to find a solution in my runtimes or in the stores.
    ...but have you lowered the constraint stiffness?
    232 x 164 - 10K
    yes, but not every hair I have tried has these parameters. Thanks for helping though, I guess I'll figure something else out for the hair.
