How do I install Bryce? 7.1 the newest version?
TSasha Smith
Does Bryce have a way to be installed such as with DIM or can it only be done manually?
How do I install Bryce? is 7.1 the latest version?
Sfariah - No, DIM works exclusively for Studio, not Bryce, Carrara or Hexagon. Here is a guide how to install Bryce: https://horo.ch/docs/mine/pdf/BryceContent_v4.pdf if you need more help, just ask.
In addition to helpful PDF document above posted by Horo, there is what you may look for in Product Library:
1)
2)
After downloading these, refer to information in Horo's content guide.
and then ~
perhaps they 'ought to change the names in Product Library:
So , peopl dont get mixed - up
thanx ~
You have to select the bryson 7 option first and download those. Then, you'll be able to install the bryson 7 pro materials. When installing the Pro content, there will be a screen that asks if you want to unistall the previous Pro content. (select no)
