Link to Studio 4.20 broken
Hera
in The Commons
Tried this morning to download Studio 4.20, as I'm interested in the volymetric options in that release, but the link appears to be broken. I'm only redirected to https://www.daz3d.com/dazcentral - and that page seems to be a dead end.
Does anyone know if Studio 4.20 is possible to download at this time?
It seems there's a problem with that link. It should be https://www.daz3d.com/dazcentral
AFAIK it's no longer possible to download DS, other than via DAZ Central.
The most recent version of Studio is available in your product library - filter by "DAZ studio 4." (or perhaps this link works as well: https://www.daz3d.com/downloader/customer/files#prod_13176)
No need to use DAZ Central
It also should be available in Install Manager.
Along with Studio , the default plugins and default resources were also updated.You'll want those aswell because some of the new features rely on that updated default resources package.
DIM makes this easy to update, but one can always go to their product library and download all the updated files and download/install manually.
If something isn't working check and make sure you have all the updated packages for 4.20.
It is 'Hidden' in my Install Manager. Why? Is there a reason I should not be downloading it with DIM? Windows Users? Windows users pre-11? Direct me to Connect?
I attach my settings.
You must have hidden it at some point in the past. I have never seen anything hidden that I did not myself hide.
Studio cannot be installed with Connect. I must be done with DIM (or Central?) or use the standalone installer (exe). If DIM is your preferred method of installation for content, use it to install Studio (shut it down first). Any dependent plugins will also need to be updated or they will no longer work. They will have "4.20" in the product name, like "Measure Metrics for DAZ Studio 4.20+".
If it's hidden you presumably hid it - things are not hidden by default or on the Daz side.
