Link to Studio 4.20 broken
HeraHera Posts: 1,962
Tried this morning to download Studio 4.20, as I'm interested in the volymetric options in that release, but the link appears to be broken. I'm only redirected to  https://www.daz3d.com/dazcentral - and that page seems to be a dead end.
Does anyone know if Studio 4.20 is possible to download at this time?
  • StargazeyStargazey Posts: 274
    edited February 2022
    It seems there's a problem with that link. It should be https://www.daz3d.com/dazcentral
    AFAIK it's no longer possible to download DS, other than via DAZ Central.
    Post edited by Stargazey on
  • NathNath Posts: 2,989
     The most recent version of Studio is available in your product library - filter by "DAZ studio 4." (or perhaps this link works as well: https://www.daz3d.com/downloader/customer/files#prod_13176)
    No need to use DAZ Central
    It also should be available in Install Manager.
  • IceCrMnIceCrMn Posts: 2,331
    Along with Studio , the default plugins and default resources were also updated.You'll want those aswell because some of the new features rely on that updated default resources package.
    DIM makes this easy to update, but one can always go to their product library and download all the updated files and download/install manually.
    If something isn't working check and make sure you have all the updated packages for 4.20.
  • DiomedeDiomede Posts: 15,401
    It is 'Hidden' in my Install Manager.  Why?  Is there a reason I should not be downloading it with DIM?  Windows Users?  Windows users pre-11?  Direct me to Connect?
    I attach my settings.
    489 x 363 - 35K
    372 x 641 - 46K
    427 x 616 - 48K
  • NorthOf45NorthOf45 Posts: 5,747
    You must have hidden it at some point in the past. I have never seen anything hidden that I did not myself hide.
    Studio cannot be installed with Connect. I must be done with DIM (or Central?) or use the standalone installer (exe). If DIM is your preferred method of installation for content, use it to install Studio (shut it down first). Any dependent plugins will also need to be updated or they will no longer work. They will have "4.20" in the product name, like "Measure Metrics for DAZ Studio 4.20+".
    If it's hidden  you presumably hid it - things are not hidden by default or on the Daz side.
