No Product to Apply HD to all Genesis 2 Males?
inquireinquire Posts: 2,464
I'm guessing that there is no product that will apply HD to any Genesis 2 male. Is that correct? There has to be a specific texture that is HD. Is that right? On the other hand there is a product named "Vascularity HD" that will apply just the vascularity to a Genesis 2 model. Is that also correct?
Post edited by inquire on
  • nemesis10nemesis10 Posts: 4,032
    No, not a texture...: perhaps this will make it clearer... http://www.daz3d.com/forums/discussion/49958/ Think of HD as a morph made with higher resolution modeling; it is texture independent since it is topography...
    Vascularity is a confusing example because there are two ways to do it — either as a morph, which deforms the mesh and works on the figure no matter which UV map the figure's texture uses, or by using an overlay on the Displacement texture map, which does depend on which UV map is applied to the figure.
    If you're looking at an "Apply HD" thumbnail in your content, be aware that this is probably an "apply at 100%" setting. The HD morph itself will have a dial in the Parameters or Shaping tabs. Unlike a texture, it isn't all-or-nothing, you might not always want to apply it at full strength.
