Is there a way to get rid of the fake looking shininess in V4 hair?
VicS
I have tried every slider i can think of and made it into uber shader
I figured it out, i need to select each field in surfaces which i hadnt beenn doing but there are still areas that remain from slightly to very glossy
Redacted
Redacted
Thank you, I didnt have a chane to try it yet, I wanted to try it firsat before ai got back to you, I think Im a little scared because it is not 100% clear what to do, I have downloaded the 2 materials-I will try it and am also so busy with all the stuff I have in my library creating new art work, the more you buy the more overwhelming it becomes-
thank you always for all the help you give me! I always really appreciate it.
Is it correct to choose all the matereial zones and put in the jpgs you sent me , all at he same time like I have done?
I put the second image in glossiness channel (after I took screen shot but didn't seem t omake that much of a difference, yo were right the fix is very easy,
I dont know ifI have done it corretly but it looks good enough now I do think, I wwanted it to look as good as the v3 hair (the long style in image),
I rencently found out that the hair for M and V 3 looked better than the ma dn v4 did, - when I see the newly modeified v4 hair in a scene I be able to tell better if the hair looks as soft as the v3 hair does-
If it looks as good then I will have mnay more hair styles to use, if it doesnt lookas good I can always use thoise hair stlyes more in the back ground blurred out somewhat, so this was very helpful, Thank you
here's one example why I got inspired to start getting all these v3 hairs that while they were on sale, they all render nicely too, some better than others, but all pretty good
forgot to pu the image-oh I did put it, but when I deletet the same image tyhat remains in the attach file area the one Iposted got deleted, so here's the image from my first part where I wrote
I put the second image in glossiness channel (after I took screen shot but didn't seem t omake that much of a difference, you were right the fix is very easy,
-now it wont uplaod at all, so here's a link instead
https://ibb.co/ssxGmDQ
