Is there a way to get rid of the fake looking shininess in V4 hair?
I have tried every slider i can think of and made it into uber shader
3003 x 1761 - 4M
  • VicSVicS Posts: 1,273
    edited February 2022
    I figured it out, i need to select each field in surfaces which i hadnt beenn doing but there are still areas that remain from slightly to very glossy
    2764 x 1735 - 3M
    Post edited by VicS on
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
    edited May 2022
    Redacted
    Thank you, I didnt have a chane to try it yet, I wanted to try it firsat before ai got back to you, I think Im a little scared because it is not 100% clear what to do, I have downloaded the 2 materials-I will try it and am also so busy with all the stuff I have in my library creating new art work, the more you buy the more overwhelming it becomes-
    thank you always for all the help you give me! I always really appreciate it.
    Is it correct to choose all the matereial zones and put in the jpgs you sent me , all at he same time like I have done?
    I put the second image in glossiness channel (after I took screen shot but didn't seem t omake that much of a difference, yo were right the fix is very easy,
    I dont know ifI have done it corretly but it looks good enough now I do think, I wwanted it to look as good as the v3 hair (the long style in image),
    I rencently found out that the hair for M and V 3 looked better than the ma dn v4 did, - when I see the newly modeified v4 hair in a scene I be able to tell better if the hair looks as soft as the v3 hair does-
    If it looks as good then I will have mnay more hair styles to use, if it doesnt lookas good I can always use thoise hair stlyes more in the back ground blurred out somewhat, so this was very helpful, Thank you
    here's one example why I got inspired to start getting all these v3 hairs that while they were on sale, they all render nicely too, some better than others,  but all pretty good
    926 x 868 - 948K
    forgot to pu the image-oh I did put it, but when I deletet the same image tyhat remains in the attach file area the one Iposted got deleted, so here's the image from my first part where I wrote
    I put the second image in glossiness channel (after I took screen shot but didn't seem t omake that much of a difference, you were right the fix is very easy,
    -now it wont uplaod at all, so here's a link instead
    https://ibb.co/ssxGmDQ
