Tranparent Sphere
Is there a way to place a primative sphere inside a sphere and make the outer sphere look like a transparent glass ball and the inner sphere look like a glowing ball. Simular to the attached photo. I tried one of the iray glass shaders on the outer sphere but the emmissive ball inside did not show very well.
  • QuasarQuasar Posts: 705
    What glass shader did you use? I'm guessing the outer ball was acting like a solid glass object. You could try turning on the "thin walled" setting in the shader settings of the outer ball.
  • kwanniekwannie Posts: 870
    Thanks Quasar I'll give it a try.........btw it was just a clear glass shader in the Iray shaders folder
    Any luck? You could increase the emissive light brightness also. I have changed settings in the Iray render settings to get brighter light as well.
  • maybe you need a sphere with thickness
    you could reverse the normals on a second one inside
