Volumetric Effects in Daz Studio.
12467…11
    Fluidos II works with VDBs, but I don't think it can output them.
  • galiengalien Posts: 150
    I think that Fluidos II automatically saves the vdb files (in the folder set for the simulation files) when you run a simulation.
  • kyoto kidkyoto kid Posts: 42,486
    ...ah so in using Daz itself it's out of the question.  I have the most recent version of Blender that still supports W7 so may have to give that a try. Would be great for creating elemental spirits.
  • IvyIvy Posts: 7,165
    edited February 2022
    being able to render "Motion Blur" would be awesome . right now the motion blur effect has to be done in pre production & it can be time consuming
    This is a model i made of my car a 1998 - 3000gt vr4 I rendered these scenes in iray  using stone masons urban future3 set
    In order to make the motion blur look right it had to be setup in pre production first in 3DL and render with the motion blurr in the background.   because 3dl can render motion blur, and I do not think no one going to notice much if the motion blur effect is iray or 3dl  .  So then I rendered everything in the scene in Iray to bring out the details.   its time consuming when setting scenes up for animation, so a built-in tool for motion blur would be great addition to daz iray.
    This set up took like 15 mins and about 5 minutes to render in 2 layers to make the motion blur effect. these renderers are in 4k sizes  so if you click on them you'll see the pre production technique  gives good results
    2560 x 1440 - 278K
    2560 x 1440 - 249K
    2560 x 1440 - 227K
    2560 x 1440 - 232K
    2560 x 1440 - 506K
    Post edited by Ivy on
  • charlescharles Posts: 866
    Looks cool!
    Is motion blur related to volumetric effects in some way?
  • RobotHeadArtRobotHeadArt Posts: 917
    There is also a feature for using inhomogeneous volumetrics without having to use a VDB.  In the Render Settings, under Environment, there is a new Atmospheric Ground which uses the volumetric MDL on a dynamically created cube aligned with ground.  You can use this without needing to create and import any VDB files.  Here are some examples.
    It doesn't generate any wisps but I think it is better than the SSS cube trick we had before.
    500 x 650 - 439K
    650 x 500 - 493K
    Post edited by RobotHeadArt on
    Not as I understand it, no.
    No it not , its 2 different things. Motion blur is effect to give the viewer the feeling of there is some kind of rapid  motion. Its something to add to the wishlist. Iray does is not cable of motion blur as far as I know.& motion blur is a popular effect in most other 3d software. as is volumetric, particle & physics . its very useful for animation effects
    How fast is this implementation if I may ask? Does it take up a lot of cycles?
    Post edited by Paintbox on
    The ground fog doesn't seem to add much extra render time.  I didn't save those scenes so I don't have the redner times.  Using a VDB is going to really depend on the size of the volume and how it is lit.  If you have a light inside a volume it's going to be more slow because it has to calculate the light interacting with the different densities.  Probably best to wait until the official shaders are released to see what the speed will look like.
    ...so which beta is this available in? I'm still on 4.16.1.40
    It is available since version 4.16.1.21: Environment -> Ground Fog -> On
    ..thank you.
    Next question, which release introduced the volumetric effects?
  • SimonJMSimonJM Posts: 6,108
    My main fear is that the volumetrics will demand a version of nVidia gfx driver that is not supported by Win 7.
    The Iray update thread lists the minimum driver versions. https://www.daz3d.com/forums/discussion/529616/daz-studio-pro-4-16-1-was-4-15-1-nvidia-iray#Comment_7277511
    ..yeah I'm on the last driver available for W7.  Will be a few months before I can upgrade to W11 Pro (still no Retail version available).
  • Ghosty12Ghosty12 Posts: 2,093
    Here is my second image using Daz Studio 4.20, loving the new ground fog option.. smiley
    1000 x 600 - 446K
    Post edited by Ghosty12 on
  • JB007JB007 Posts: 141
    So is the ground fog all that us non-PAs have available or .. is there a button somewhere in 4.20 that I have to press to add Volumetric loveliness ???
    The basic ground fog option is a part of the environment tab.. And the settings I have in that image will give a nice knee high pea soup type fog..
    400 x 891 - 90K
    Yeah, I saw that .. I take it that's all we get then? And any VDB in the shop is just something that gets added to the scene?
  • How do I load volume? I am not seeing it anywhere.
    Pretty much yeah, a best guess is that the tools to do the fancy stuff will be PA only..
    Oh right .. I think I'll pass then .. there's only so many rocket launches I want to render (... about 1 .. for the record)
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,826
    well the shadermixer options are available to all, as is the Nvidia MDL stuff, it is more brains only and I missed out on that plugincheeky
    the blessed ones brainswise not just PAs, could cook us up an animated VDB sequence using a job file like Casual's Texanim does with images maybeenlightenedas animated is an option in shadermixer, I just don't now how to do it
    I can make my own VDB files, Blender can do it as can Houdini Apprentice I believe too
  • ecks201ecks201 Posts: 490
    Same here.
    Have Daz put out any basic instructions on this?
    I see Sales have got Jumbo's flying though clouds etc
    But a simple tutorial on how you make a smokey cube wouldn't go amiss
    The problem is that there seems to be no information on how to import VDB's into Studio.. We know it can be done due to this product https://www.daz3d.com/ka-rocket-launch-vdb but that is it.. indecision
    I've managed to load a VDb, but the onscreen version is nothing like the example image.
    I get a blocky white cloud, instead of round and fluffy frown
    on their own they sort of work but in scenes I am not getting good results at all, tried a sphere as well as a cube, there are actually 2 cubes in the second one but because it is obscured partially by the cauldron (supposed to be fire) it vanishes.
    they don't seem to like intersecting stuff or each other at all
    I cannot colour my Octane VDB's but they don't behave like this and do accept coloured emitters inside lighting them, the tiny emitter under my cauldron ignores the fire VDB you simply cannot see
    1920 x 1080 - 1M
    1920 x 1080 - 2M
    3840 x 2160 - 2M
