"Distant Lights" refuse to render to Canvas
well as the topic says I can figure out how to make the distant light render to a canvas,..everythjing I've tried just renders out black
Are they working in a regular render? What is the Environment Mode set to in Render Settings (after adding an Environment Settings node or doing an Iray or Filament render or draw)?
appears like it should,.. and scene only
Which canvasses are you using?
I've tried it as a Lightgroup, w/ the distant light selected in the nodegroup, I also did a LPE, with Advanced node on the Distant light named Distant and the Expression <L'Distant'>.*E
So Apparently, Distant Light,. is considered Enviroment,.. not a light like the other lights, but I guess I shouldnt be surprised, the emission never does well for me.. use light group for them as well as normal lights so why would Distant not be head scratchingly weird,
